Author Topic: Retro Rides 2010. August 6/7/8th  (Read 14600 times)
Eklipze3k
Re: Retro Rides 2010. August 6/7/8th
« Reply #15 on: July 22, 2010, 11:40:18 AM »
Hi I wanted to go as well but looks like I won't be able to go, just back from hols.  What is the Elgin Rally? if it is a car meet I may be able to attend a wee bit up the road from me.
http://www.speyside-stages.co.uk :)
« Reply #16 on: July 25, 2010, 11:57:07 AM »
If anyone wants to take there 126 on the track These are the Rules.
RR Gathering 2010 Track Attack
Obviously this isn't a competitive event and just for fun but we still need to have some safety requirements.
Cars must have valid MOT *
Drivers must have Valid D/L Licence *
*(These will be check prior to the event as part of the sign on process, including the Haynes disclaimer)
Helmets will be worn when on circuit – fastened correctly
Arms need to be covered down to the wrists.
Seatbelts (where fitted) must also be used.
Windows will only be permitted to be down a max of 2 inches if it's blisteringly hot otherwise kept closed.
No Passengers on track - Drivers only
There should be no loose items in the car so don't turn up with all your camping gear shoved on the back seats (your time points score would be rubbish anyway
Slick tyres are NOT Permitted
No refuelling in the track area
Max 10 cars inside circuit per session (in each session each car will run 3 times in starting order) – the area will be segregated and conned and will be as far as practically possible from the parts of the circuit in use.
A visual check for any fluid leaks (Water or Oil) as well as for loose items inside the car will be carried out by the “Safety Controller” in the pre-staging area – any issues would need to be resolved before going on circuit – this may potentially result in the car being asked to leave the pre-staging area.
Any cones around the circuit do not indicate braking or turn in points and may also be used to keep cars away from any damaged/hazardous surface (we have that hairpin in mind when we wrote that)
We've established a control team who are going to manage the activity hopefully we have learnt just a few things from last year and this year is going to be even better.
All “Controllers” will have quick access to a fire extinguisher, The recovery vehicle will also have one and one will be located at the furthest point from the control area.
Circuit orientation will follow once I've cleaned up the jpeg but in summary it's planned to run anticlockwise (ie opposite direction to last time)
Only one car will be on the circuit at any time - however with the circuit layout planned it would be expected that once a car had started and was on circuit (completed the first lap) the next competitor would be waiting at the start position (not part of the circuit after the previous car has left the start).
As last year part of the track is used twice (with a small twist) – failure to follow circuit direction correctly will result in void run.
On the first circuit a conned chicane will be part of the circuit Contact with these cones will incur penalty points. (plus they leave a nasty scuff mark on your paintwork)
On the second circuit the Follies Curve will be used.
The course terminates in a “boxed area” stop - Cars finish stationary with all four wheels inside the box – wheels outside the box will require the car to be reversed or driven forwards until all wheels are inside the box when the run will be considered complete.
Perhaps the above needs further explanation so here it is
As a result of a review of the last years event we’ve listened to the points raised and reversed the track direction – this left us with a small safety issue - The run down to the finish is heading towards the pre-staged cars – last time we were allowed to pre-stage the cars inside the fencing as the finish was the slowest part of the track (except when the actions of phoenixescort and his almost “sena like” approach was involved) – in order to ensure speeds at the finish point are “safe” for everyone inside the circuit braking will need to be carried out early in order to stop inside the box – with a safe margin for error before the pre-staged car area.
Obviously as we are “unable to time the event” a cunning points system will be used to produce class results - still working on that
« Reply #17 on: July 31, 2010, 07:29:11 PM »
We have 2 spare passes for the Club126UK Stand at RR. If there is any members 126/500 that are local that want a good day out with track action :P 8) We have places on our stand, Please send me a PM [-/
Please note The admission fee is £7.50 each on Sunday (showday)
« Reply #18 on: August 02, 2010, 08:05:44 PM »
Thought I would just say that if any of you guys are thinking of going to this event but have not decided  then the track part is an additional option so you can just turn up , park up & shoot the breeeze  8)
I was fortunate enough to turn up last year just in time last year to witness Bis 13 doing his bit , a memorable event. I have heard on the vine that Pete in his Bis is going for a pink slip shoot out with small cox in the aircooled turbo  [-/
Or was that just a dream ...............  :oops:
« Reply #19 on: August 02, 2010, 09:32:31 PM »
As you get older you do tend to nap and dream allot </4 </4 </4
« Reply #20 on: August 03, 2010, 10:18:17 PM »
4 days to go :P anyone else coming to join us :D
« Reply #21 on: August 03, 2010, 10:30:57 PM »
 ;) Can you tell me more about your condition  ???
                      I want to plan ahead    [-/
« Reply #22 on: August 07, 2010, 01:05:56 AM »
Hopefully , I can get there in my Fiat. It is more that 100 miles to get there. Well I got to Stamford Hall which is also a similar distance. Wish me luck!!!!!!!!!!
« Reply #23 on: August 08, 2010, 08:12:06 PM »
PS. Smallcox's car sounds even sweet-er than it looks [-/
All those who didn't make it, you missed-out on a fantastic weekend.
Pete did 270 miles each way from Leeds, Steve was on his way back from Cornwall and had an estimated 6 hours to get back to his in a car that can sit at 70. The other two cars didn't have that far to go but proved 126's can travel....
Mine sat at 70 all the way back home bar going up hills, didn't miss a beat.
Hope you guys all got back ok [-/
« Last Edit: August 09, 2010, 09:07:22 AM by Darrell »
smallcox
« Reply #24 on: August 09, 2010, 12:34:44 PM »
WOW-Great weekend even better than the holiday in Cornwall [-/
Took 5 hours to get home in the end M3, M25 traffic but the wife didn't moan to much so all good and the little engine made in back to Essex 8)
Your right Darrell they are more reliable than poeple give credit for, shame on those who don't believe but just in case theirs always the RAC    :oops:
Thanks guys and all for a great weekend [-/
« Reply #25 on: August 09, 2010, 08:39:22 PM »
Nice to see the 126 stand taking pride of place on other sites too :-)
http://retrorides.proboards.com/index.cgi?board=rrg2010&action=display&thread=86075
« Reply #26 on: August 09, 2010, 09:44:18 PM »
It was a pleasure to meet you guys. It was a great day out and was fantastic to see four 126s on the day. Steve, congratulations again for the engineering award. The modifications you did was definitely an engineering feat - absolutely amazing. Pete, many thanks for showing me the many modifications on your car. I will definitely have another go with the headlight protectors.
It took me three hours to get there and 135 miles but took over 5.5 hours on the return journey as the traffic was horrendous on the A303 and A406 (resurfacing at Staples Corner causing a tailback all the way back Chiswick roundabout) but my little Fiat survived it. Cruised at +70mph no problems, the car appears to prefer these speeds. I am now quite confident driving my baby Fiat long distances. The car has been quite reliable. Darrell/Steve you guys are right in terms of giving credit to the car but I think others do not seem to enjoy the same level of reliablilty as we do. Hope to see you on other meetings and events.
« Reply #27 on: August 11, 2010, 11:42:21 AM »
Looked great!  Sorry we could not make it but our nine month old takes up a lot of time......maybe next year!
« Reply #28 on: August 11, 2010, 12:36:05 PM »
 :oops: Like I said to Darrell & his lady " as a photographer I make a great ice cream seller "
But I did get a shot of smallcox entering the battle arena  [-/
Then waiting for the green light  ;D
« Last Edit: August 11, 2010, 10:24:04 PM by Pete126 »
« Reply #29 on: August 11, 2010, 11:08:52 PM »
What a fantastic weekend :P No breakdowns [-/ and it was good to meet up with friends old and new to have a few beers with :P
Congratulations to Steve (Smallcox) With his 126 Turbo, Winning the trophy for Best engineered car at the show [-/
A Big Thankyou to tonylanciabeta for taking these pictures
See his complete set here http://www.flickr.com/photos/tonysphotos/sets/72157624557190123/
