Author Topic: Disc Brake preperation!  (Read 3548 times)
« on: January 22, 2010, 08:17:55 PM »
Right got my disc kit of Rusty and it all looks great!  However need to clean the calipers first before I paint them, what would be the best stuff to clean them with?
Re: Disc Brake preperation!
« Reply #1 on: January 22, 2010, 08:29:57 PM »
Use a wire brush, but take care not to damage the piston and rubber dust shield. Brush them down with thinners before you paint them to remove any oil or grease [-/
« Reply #2 on: February 09, 2010, 11:49:22 AM »
 :) I missed this post because it was posted on my birthday & I was away for a long weekend. I found it when I was looking for Pete's mention of the bloke that breaks Cinquecentos but can't find that post. Anyway I will seek out his e-mail address as I have been in touch with him and he does a great service as I just got some more complete callipers / carriers from him. So I would definately recommend him. I have so far not completed a full resto on any callipers as it is a bit of a labour of love which is probably why the refubished callipers ones (without the carriers & all the other little bits you need)  are so bloody expensive.
Anyway generaly the callipers are in pretty horrible looking condition when you get used ones. I stripped them down being careful with the seals. I had a real problem getting the pistons out from the first set so with the next set I glued a valve set up from a normal car or cycle inner tube (just cut it out) in the end of the Cinque flexible hose so I could get my footpump on it and with a couple of pumps the pistons just popped out. I then dunked the calliper bodies & carriers into my high tech washing soda , mobile phone charger powered rust removal tank (see other crackpot thread) which worked a treat getting back to bare metal.
to be continued  :oops:
« Reply #3 on: February 09, 2010, 06:10:55 PM »
OK back on the case so I did a lot of research on different forums about caliper restoration and I think a lot of it comes down to preparation. If you give a rusty caliper a quick scrub & paint job it will probably look rough in a few weeks. You need to get back to clean metal then there seemed to be 2 options that have been mentioned. Two pack disc brake epoxy calliper paint and smooth Hammerite. So after reading a good report on one forum about the Hammerite I am giving it a go. The tip suggested that you thin the first coat to get a good key into the surface but I went one stage further and bought Hammerite Kurust to brush on the surface just in case. I do have to say that it seems to be a great preparation & if you go for it a very small amount goes a very long way. I added about 30% Hammerite thinners to some smooth red paint and it dried up almost invisible but felt good. But brushing this smooth Hammerite is quite wierd and difficult to get full coverage but I am part way through the process & I reckon that I will have to put on 3 or 4 coats . Bit of a pain but they are starting to look gooooooood !!  :D
to be continued .....................
« Reply #4 on: February 09, 2010, 06:38:29 PM »
This is great but what exactly did yiou clean them with?
« Reply #5 on: February 09, 2010, 07:01:43 PM »
The guy that sells the Cinquecento stuff has the e-mail address
  [email protected]
I had a chat with him about parts that may be of interest , things might include seats , coloured seat belts & dash items  [-/
« Reply #6 on: February 09, 2010, 07:03:23 PM »
Sorry found the other post now! :oops:
« Reply #7 on: February 09, 2010, 08:30:56 PM »
I had mine media blasted (carefully) by my local powder coater then treated them to some por 15 the some 2 pack black look spanky still!
« Reply #8 on: February 10, 2010, 05:08:25 PM »
Brake calipers as received
« Reply #9 on: February 10, 2010, 05:10:40 PM »
Caliper stripped & after rust removal
« Reply #10 on: February 10, 2010, 05:33:18 PM »
Calipers after KURUST application
« Reply #11 on: February 11, 2010, 02:11:57 PM »
Suffering slight "Hammerite Brushing Fatigue" but getting there. The paint , Kurust & thinners  I got from my local traditional hardware store as even with my 10% discount card at the local DIY superstore  it was way cheaper and the only price I remember there was for the Hammerite spray cans that they had at £18.50 :o
Anyway got one other set of calipers under resto so popped into another local hardware shop this morning and they had cans of smooth black at £9.60 so went for that and giving that a try now. So in between coats I had a look on good old eBay . Just ordered 3 more cans , delivered for £20.50  [-/
I seem to be only able to load one picture per post so here is one of parts getting a shine on  ;)
Re: Disc Brake preparation!
« Reply #12 on: February 11, 2010, 02:18:39 PM »
 They are starting to look good [-/ Are you gonna paint Brembo on the side?
« Reply #13 on: February 11, 2010, 03:14:49 PM »
 ;) I think Bambino might be more better  :oops:
Hey Stuey , tell us more abou the stuff you used  [-/
« Reply #14 on: February 11, 2010, 06:22:55 PM »
 Rusty lets make a compromise and do them Brembino... :oops:
