Author Topic: Gearbox problem...  (Read 1288 times)
Josip
    • JoeXmas Photo
Gearbox problem...
« on: October 04, 2009, 10:31:01 AM »
I was driving a day ago, and I don't really know how it happended I noticed on a straight road... my reverse gear is gone, well... gearbox moved somehow, now 1,2 gear are good, 3,4 you have to press down like going to reverse and you can shift, reverse is gone...
Any ideas, solutions?
Re: Gearbox problem...
« Reply #1 on: October 04, 2009, 12:07:38 PM »
check that your engine mount is tight , that the engine to gearbox bolts are tight and then check the gearbox mount it sounds like it has shifted also have a look to make sure the rear panel is done up tight.
