Author Topic: sagging roof  (Read 4890 times)
Re: sagging roof
« Reply #15 on: July 03, 2009, 11:23:34 PM »
you want to get the stuff thats on about 2mm thick and if you have a haberdashery shop near you get some lining foam thats about 5mm thick and cover the mdf with that then cover with adhesive and apply your cloth make sure before hand that one the glue does not melt the foam and two that the cloth is thick enough to not let the glue absorb through . try using vinyl and if your clever you can punch buttons in at equal distances to make it look super sexy.....
Re: sagging roof
« Reply #16 on: July 04, 2009, 07:44:33 AM »
making a new cardborad is what worries me, any1 got the dimensions for the thing? dont have anything that big to make a template  :oops:
so you guys reckon it would reduce the noise in the car?
Re: sagging roof
« Reply #17 on: July 04, 2009, 08:44:52 AM »
thats a fact as the roof amplifies any noise in the car even just foam stuck to the roof would make it quieter as the sound waves would not bounce of the roof so easily.
Re: sagging roof
« Reply #18 on: July 04, 2009, 09:33:31 AM »
cheers mick, ill see if i can get a new original one from my supplier  :P
defender90
Re: sagging roof
« Reply #19 on: July 04, 2009, 05:29:26 PM »
    Chaps, that would be Hardboard you need not MDF, I once re-stuck an old Jag roof lining cloth back to the board in situ using a can of spray glue that had a straw type attachment. Made a very small hole in the cloth put the straw through and sprayed it all round before pulling the straw back out and sticking the cloth back up, when done you ccouldn't see the tiny straw hole.
Kevan
Radcliffe
Gt.Manchester
Citroen BX TDG (soon to go)
Citroen BX TZD
Land Rover 110 Station Wagon
Re: sagging roof
« Reply #20 on: July 05, 2009, 10:14:46 AM »
the original was hard board and i replaced one in my first bis with thin mdf (its about 2mm to 3mm thick) and is much lighter and easier to use the original had about 300 holes in it to keep the weight down and make it more flexible .
Re: sagging roof
« Reply #21 on: July 06, 2009, 09:38:56 AM »
Just an idea, what if I didnt use mdf and just put like 12mm foam to the roof, and then stick material strait to that..think you know where I'm going with this.
I was thinking a special hood lining covering the whole roof.
Re: sagging roof
« Reply #22 on: July 06, 2009, 09:46:38 AM »
Hi Darrell , got them disc brakes fitted yet ? Re the roof I have had a couple of 126s where the headlining has been replaced by wide (Just one join down the middle) , about 6mm thick , self adhesive firm foam rubber . Not sure where you get it from these days but sure it is out there  [-/
Re: sagging roof
« Reply #23 on: July 06, 2009, 09:50:32 AM »
Hi Rusty, just fighting with the wife to stop buying dresses etc so I can get callipers discs etc.
I am thinking of getting the plates powder-coated as my wheels are rather see-through and you'll be able to see them so want them to look smart...not that the rest of the car is smart hehe :oops:
Re: sagging roof
« Reply #24 on: July 06, 2009, 09:59:58 AM »
I would be a little concerned about powder coating as although it is quite tough it is a plastic after all and will give and could leave you with loose calipers.  :oops:
I have got the new batch made up now & have been thinking of getting a quote for Zinc plating . I will probably have the set I use done at least.
Re: sagging roof
« Reply #25 on: July 06, 2009, 10:07:23 AM »
Good idea  [-/
fightingtorque
Re: sagging roof
« Reply #26 on: July 08, 2009, 10:53:00 PM »
I'll look into it.  Got a few other things to update (improve the wiring for my fuel injection and add a fuel swirl chamber, new MOT etc).
Gav
