Author Topic: Recession Beating Restoration  (Read 6086 times)
nrg19uk
Re: Recession Beating Restoration
« Reply #15 on: January 28, 2009, 10:36:42 PM »
i found some leftovers from christmas and so mixed up a mixture using branston pickle , sweet pickled onions , and some turkey gravy, ave a look as it bought up me gearbox a treat.. ;D
looking clean whats the plan?
Neil gargaro
« Reply #16 on: January 29, 2009, 12:48:55 AM »
no i shall rub garlic over it to ward away unwanted beasts..
« Reply #17 on: January 30, 2009, 12:37:38 PM »
Ok , about one week into the experiments and some progress but I disposed of the Coke & Bicarb mixture to try out a solution of washing soda . Sorry Mick but I reckon that it would have had too much iron in it anyway ! But I do have to bow to your superior knowledge  ^8) on recipes , you must surely be the Gordon Ramsey of the car restoration world  ;) I can't quite get to the bare clean metal stage that the web site says you can get but I do have to say that very heavily rusted exhaust brackets shed some pretty heavy chunks of rust pretty much over night and would be good preparation for painting but I was hoping to go a stage further and investigate metal plating which I need to swot up on  :study: I kind of fancy a few gold plated items under the car to impress the MOT man  [-/
joda
« Reply #18 on: January 30, 2009, 02:30:20 PM »
the magazine in question is practical classics from about september-november, as i remember reading the article on the aeroplane in october, but left the magazine in america >:(
was keen to build a simmilar set up but i cant since i lost the mag :(
126Bis
« Reply #19 on: January 30, 2009, 02:36:23 PM »
have a look in the frost catalogue i am sure they sell metal plateing kits,as for exhaust brackets i suggest a good lime pickle mixed with raw onion , brush it on and leave it for three hours then place in a low oven for three days lol.
« Reply #20 on: February 27, 2009, 12:36:10 PM »
 :) Update on rust removal - I tried out a number of options then I got a pair of Cincecento disc brake calipers this week that were seized and heavily corroded so I went for the immersion in a bucket of 35p worth of washing soda solution. A piece of plain sheet steel curved to the inner shape of the bucket and the connection to a mobile phone charger with a couple of crocodile clips on the wires. The item being "cleaned must not touch / short out on the metal plate and you know it is working when you get some fine bubbles. Incredibly low power consumption with an output of 5 volts & 120milliamps. This process seems to attack the rust from the base item surface rather than eat it away from the outside in. Net result is the rust coming away in thick chunks and I mean thick with some bits about 2mms thick. After 48 hours the rust that had not fallen off was easily removed with a wire brush leaving a surface that was about as good as sandblasting  </4
« Reply #21 on: February 27, 2009, 03:14:51 PM »
thats wicked have you tried anyother types of metals , see what the results are i might have a look at that just out of curiosity did you look at the frost site by the way? as they have all sorts of kits even anodising kits ! i can just see you turning all metals purple lol.
« Reply #22 on: March 01, 2009, 07:18:38 AM »
 :- I have not tried it on any other metals because most of the non ferrous bits I have are just dirty rather than corroded and I did not wnt to run the risk of ruining a carb for instance. As for plating I have met up with a guy who reckons his nick name is "Chemical Ali" so I am going to try that avenue , or should I say Ali  </4 </4
« Reply #23 on: June 19, 2009, 05:57:27 PM »
 :) Just because I have not prattled on about my experiments recently does not mean that they are not ongoing but it is now a case of just putting what I have learnt into practice plus a little bit of upping the scale. Low level acids like vinegar & coke are safe to use & will remove rust and the dirt cheap basic products ( the ones that the government base the inflation figures on)  :rant: have the same active ingredient levels as the more expensive brands. If you are not in a hurry just dump your rusty bits in a bucket of the stuff & leave it for a week & see how it turns out.
The greatest success with very rusty parts has been the washing soda & phone charger method although my initial 1 gallon tank seemed to clap out after a number of weeks & many components. I did notice that the steel plate that formed one of the electrodes had rusted quite a bit.
So I invested another 69p in a bag of washing soda , went to the charity shop & bought a stainless steel tray for 50p then got one of the recyc boxes/tubs that blow around the block on a windy night  </ add a few gallons of water and clipped on the old mobile phone charger to the tray and the other wire to a 12" Fiat steel rim. Turning the rim each day in relation to the stainless tray this process has removed all of the rust which was very heavy plus much of the old paint. Crazy , low cost & it works  </4
K666STW
  • 704cc of pure fury.
« Reply #24 on: June 20, 2009, 02:50:44 AM »
With regards plating stuff. My dad has got a wee nikel plating setup. Old paint pot couple bits of wood and a mechano motor to help keep everything moving.
If you need any info on it I'm sure he'll be more than happy to spread the wealth. :)
sideways
« Reply #25 on: June 21, 2009, 01:20:26 PM »
i bought some rust remover stuff a while ago and much to my surprise it was basically coke! exept more of a syrup lol it works really well aswel lol
