Try Rotating the distributor while someone is turning the engine over on the Key,
Make sure the 2 nuts on the rocker cover are not too tight, cause if they are they could fowl the top of the valves and stop them from closing so you get no compression.
Have you Checked the static timing on the front pulley.
If it still won't start, align the timing marks on the pulley, take the distributor out and rotate the engine 1 revolution, then drop the distributor back in and set up the timing again
