make sure that you strip out the carpet and all the normally wet sound deadening material, then if the car leaks at least you can mop it out!!get rid of all the bits that dont matter, keep the 2 seats as you will need to take a passenger out from time to time just to confirm the fun factor! make your bis breath better by loosing the airbox and channel in some good air into a good cotton filter, if you can forget the exhaust and only use it for mot time, then weld two down pipes to some flexi tubing and fit a
bit of good old scaffold pole welded to the brackets, it will help it along a bit. theres also a timing trick but i dont want you to do it and mess your engine up then blame me lol (its all to do with the chain..lol)....and after you have stripped it out and lowered it all dont forget the 25kg of sand in the front!!
