Author Topic: Guess?  (Read 885676 times)
Re: Guess?
« Reply #2955 on: March 03, 2013, 02:58:00 PM »
Antartica? :D
pietschokkenbroek
Re: Guess?
« Reply #2956 on: March 03, 2013, 03:01:20 PM »
No mate!  ;)
jaybee
Re: Guess?
« Reply #2957 on: March 06, 2013, 10:52:03 PM »
So is that a clue or designed to put us off the scent? It looks aero engined?
Mad Barchetta owner!
Re: Guess?
« Reply #2958 on: March 06, 2013, 11:34:16 PM »
Specifications
â– Engine   DV1 Alloy V8 350 CID 5.7 litre
â– Max torque 470 Nm / 346 ft lbs @ 4400 rpm
â– Max power 361 bhp / 270 KW @ 5700 rpm
â– Transmission 4 speed automatic transmission
â– Wheels / Tyres 6" x 16" x 60 spoke wire wheels center lock, Dunlop 215 - 70R -16 "H"
â– Brakes 300mm disk all round
â– Front suspension Fully adjustable s/steel double wishbone with coil over dampers
â– Rear suspension Live axle with 4 bar links Panard rod with coil over dampers
■Front & rear track 1385mm (54½ “)
■Overall length 4800mm (15’ 9")
■Overall width 1612mm (5’ 3½")
■Overall height 1230mm (4’ 6½")
■Wheel base 2794mm (9’ 2")
â– Chassis RHS steel jig welded
â– Body GRP construction hand laminated
â– Weight: 1125 kg
â– Interior Muirhead Aviation leather
â– Seating capacity 2
â– Rear axle Borg Warner with diff ratio 3.45:1
â– Fuel tank Custom built aluminium 85 liters capacity
â– Radiator Aluminium high flow incorporating transmission cooler
â– Steering Rack & Pinion
â– Glazing Laminated screen, safety glass & acrylic side and rear screens
 ;D ;D ;D
pietschokkenbroek
Re: Guess?
« Reply #2959 on: March 07, 2013, 05:09:20 PM »
Thanks Pete  :beer: I'll drink to that :D
Re: Guess?
« Reply #2960 on: March 07, 2013, 07:06:26 PM »
Thanks for the clue the devaux-coupe-8 :D
Re: Guess?
« Reply #2961 on: March 07, 2013, 07:10:22 PM »
 :o
« Last Edit: March 09, 2013, 01:10:14 PM by Pete126 »
jaybee
Re: Guess?
« Reply #2962 on: March 09, 2013, 10:04:11 AM »
Looks like a coachbuilt Packard
Re: Guess?
« Reply #2963 on: March 09, 2013, 01:21:29 PM »
Many apologies Guys, I did initially state that the car was American, But it is 50's European. Just shows you can't always believe what you read on the internet ;D
jaybee
Re: Guess?
« Reply #2964 on: March 09, 2013, 03:22:43 PM »
I thought it was European!
jaybee
Re: Guess?
« Reply #2965 on: March 09, 2013, 03:35:57 PM »
Its a 1950 Delahaye 135ms
Re: Guess?
« Reply #2966 on: March 09, 2013, 04:35:53 PM »
Correct :D Chuck another one up :thumbup
jaybee
Re: Guess?
« Reply #2967 on: March 09, 2013, 06:06:32 PM »
Ok Try this. I'd tell you its French but I'd be fibbing!
pietschokkenbroek
Re: Guess?
« Reply #2968 on: March 09, 2013, 07:00:26 PM »
I see a lot of similarities with the Alpine A110...
Re: Guess?
« Reply #2969 on: March 09, 2013, 07:42:41 PM »
Think it might be a VW Puma. Or possibly an Interlagos (brazillian alpine). There was also a Bulgaralpine (Bulgarian alpine), but there are a load of brazillian vw sp2's in the background.
« Last Edit: March 09, 2013, 08:24:37 PM by Hazey-n-Marc »
