Author Topic: gear oil all up my street  (Read 3786 times)
phreak97
  • Niki!
« on: July 09, 2008, 04:17:24 PM »
the last couple of days my car's made a wierd noise like something sheet metal getting mangled for half a second when going to first after reversing out my driveway, and the car hasnt really moved off the first try. it only happened twice so i dont have a good description, it doesnt last long.
anyway, today when i got home i noticed theres a trail of oil which starts very thick where i'd have put it into first, then goes off up the street and turns left, which means it happened yesterday. i drove for about an hour yesterday, and half an hour today. which means i probably had very little(if any) gear oil in the box for most of that time.
interestingly it doesnt really sound any different, except theres a faint high pitched whine mostly noticeable on fourth.
what would likely cause a leak this bad? i never had any crunches or anything.. it just made an odd noise those two times (sounded like some engine tin flapping about or something, so i didnt bother with it till i saw the oil)
phreak97
phreak97
  • Niki!
« Reply #1 on: July 11, 2008, 05:45:02 PM »
its bad...
theres a crack that runs around from the input shaft round underneath the gearbox, to the join between the two halves of the diff housing, then from the join back underneath the gearbox to the other end..
both halves of the box are cracked! i must have been driving with no gear oil for those two days.. just to add to any damage that was there already..
F**K
well.. niki's off the road for another gearbox rebuild after only a year.
i had engine oil in the box as i read here, but i think ill go with gear oil this time.. a mechanic in my local fiat 500 club recommended 80w90 with slick 50 added.
other than the oil possibility, what causes damage like this?
maybe i just drive it a bit too hard?
phreak97
Normansinjunstevas
« Reply #2 on: July 12, 2008, 09:40:26 AM »
That is a real pis*er. Good luck with getting it sorted, brother.
Respect......Norman
phreak97
  • Niki!
« Reply #3 on: July 12, 2008, 01:54:32 PM »
i built up a gearbox today using all the good parts from mine plus a few bits from my heap of spare parts (both the bell housing, gear housing, and a better first/reverse gear.. the one that always wears out.. and some new crown wheel bolts)
this is the first time i've had a gearbox apart, but i think all i was lacking was confidence.. the only problem i ran into was how to undo the pinion nuts, but i called my club mechanic and he told me i can lock up the box by  disconnecting the gear selector rods (whatever theyre called) and engaging two gears at once.
havnt got it back in yet.. we'll see how it goes when i can afford some gear oil.
i think the mechanic i had rebuild the gearbox didnt tighten the crownwheel bolts enough, as the ones that werent bent or broken were just fingertight.. two had come out far enough to snap off against the inside of the housing, causing the cracks and punching a hole through aswel.
heres a couple of pics of the damage. i didnt take one of the bell housing cos it was just a very long hairline crack, not really noticable in a photo.
Click the images to enlarge
phreak97
Normansinjunstevas
« Reply #4 on: July 12, 2008, 07:48:52 PM »
"Streuth!"
That must have really clobbered the casing to knacker it like that.
I assume you'll not be using the same mechanic again.
Good luck in your attempts at the rebuild.
Respect.....Norms
« Reply #5 on: July 12, 2008, 08:20:52 PM »
Time for 'Superglue' and a bit of filler?????
 :lol:  :lol:  :lol:
Sorry, :???:  Good luck. Look at it as a lesson on gearbox building, you will now be an expert on box rebuilds.
phreak97
  • Niki!
« Reply #6 on: July 13, 2008, 04:05:55 AM »
hahaha, bit beyond superglue i think:P
the mechanic i used has closed down now, i've done all the work myself since then..
i did learn alot. i'm pretty confident i can build another gearbox out of the bits i have lying around now.. probably couldnt have if i hadnt been forced to rebuild mine.
what stops the pinion that the input shaft connects to from sliding away from the engine and ruining the casing at the other end of the box? i have a couple of those casings that have rings in them from this happening, my first gearbox locked up (from bad assembly by a different mechanic:P) and punched the pinion right through in fact. looking at a couple of half assembled boxes and also mine when rebuilding it, its pretty much just being held in by the friction of the bearings against the housing.. the angle cut gears hold it in too when youre accelerating, but i thought they'd pull it out when you decelerate.
anyone want to explain this mystery to me?
also, is the clutch return spring really required? my clutch is really stiff and taking it out helps.. plus i lost it:P how much will leaving it out shorten the life of the thrust bearing?
phreak97
« Reply #7 on: July 13, 2008, 08:38:34 AM »
The small aircooled fiats were built as cheap as possible.
If they specified a return spring, you need a return spring.
If your clutch is too stiff, thats a different problem that can't be fixed by leaving the spring out. Clean the output splinefrom the gearbox. If it's dirty the clutch wont slide freely and you will eventually snap the clutch cable.
I bought a factory manual on cd for the 500. It has the exploded diagrams of the engine, box and all replacement parts for the car. This will show you what needs to go where.
Alternatively you can go onto Axel Gerstyl's site and look at the pictures as they use them for all their parts.
A good trick with this site is to click on the union Jack flag at the top, this will translate all the text to English.
Hope this helps.
Michael
phreak97
  • Niki!
« Reply #8 on: July 13, 2008, 11:27:02 AM »
hah i guess thats true. im pretty sure it's the pedal assembly or the cable somewhere that's making it tight.. ill have a look.
phreak97
phreak97
  • Niki!
« Reply #9 on: July 14, 2008, 07:59:08 AM »
damnit.. i've lost the spring ouut of the end of one of the drive shafts..
i asked my mum if she tripped over the gearbox or anything and she said "i wasnt aware of touching anything, but theres grease on my slipper.."
i've looked everywhere within a couple of metres of the gearbox, but theres a garden just next to it which hasnt been tidied for years, if it made it in there it's lost forever.
i wish people would just watch where theyre walking.. now i have to take the other one somewhere and buy a new one. not happy at all.
phreak97
JamesY
« Reply #10 on: July 15, 2008, 10:10:17 PM »
Bummer, just when you think you've recovered from one setback, something else bites you!
Did you find the spring?
I find beer helps at this point!
phreak97
  • Niki!
« Reply #11 on: July 16, 2008, 02:19:06 PM »
haha. i didnt find the spring, but i managed to make another one fit.
it's all back together now, driving round the block proved successful, the gearbox seems alot nicer on first and reverse than my old one.. gearchanges are a little stiffer, but i cant expect everything to be the same as it used to be.. perhaps now itll go into reverse every time :)
phreak97
Normansinjunstevas
« Reply #12 on: July 16, 2008, 05:30:14 PM »
Well done, my son.
Respect......Norman
JamesY
« Reply #13 on: July 16, 2008, 08:38:28 PM »
Good work!
I'm just getting back into the mood to build up the rear hubs and brakes on my kit car now I've got some exchange drive shafts (stripped the old shafts then found that the exchange items were cheaper than the refurb  kits!).
Normansinjunstevas
« Reply #14 on: July 16, 2008, 09:45:16 PM »
Quote from: "JamesY"
Good work!
So was it you who bought that yellow kit car thing off Ebay a week or so ago?
Norms
