Author Topic: 126 seats  (Read 5361 times)
phreak97
  • Niki!
126 seats
« Reply #15 on: May 25, 2008, 10:04:33 AM »
yeah, assuming theres still metal where the handle mounts used to be.
edit:
just went and checked the "car" in my backyard.. in my doors there is no metal where the handle should be, but i made another discovery..
there are square holes the same as the ones just under the ceiling, with the same spacing as the ones just under the ceiling.. which means you could take the handle from there along with the plastic screw plugs and simply install them into the doors.
at some point ill see what itll look like, but i only have one handle to begin with.. ill need to source two more before i think of making it permanent....
phreak97
126 seats
« Reply #16 on: May 25, 2008, 05:30:58 PM »
You can screw the thing anywhere on this metal, but if there are holes, even better...
(the picture above is enzo2 s 126, hope he wont mind me using it...  :wink: )
phreak97
  • Niki!
126 seats
« Reply #17 on: May 26, 2008, 12:36:01 AM »
yeah, i know, but i dont want to do anything that was never originally on a 126. though i realize the handle holes i discovered werent used, they were quite clearly intended for it.
heres the two door designs:
i circled the holes i found in blue
phreak97
