Author Topic: WAXOIL CORROSION PREVENTION  (Read 4167 times)
Re: WAXOIL CORROSION PREVENTION
« Reply #15 on: November 01, 2010, 05:44:55 PM »
Found the old topic , hope this helps Kitten  [-/
Paint & underseal will protect the outside of your car but waxoil is pumped , sprayed or squirted into the cavities that you cannot get to to dispel moisture & stop corrosion. Still got a 2 litre bottle of my pink home made version that I hope to be using in the near future.
The best thing you can do is keep using the car as that keeps them alive but it might be worth getting your mechanic to check inside the doors etc to see if the car has been rust proofed  :D
kitten75
« Reply #16 on: November 12, 2010, 12:51:18 PM »
Cheers Rusty - just noticed your re-posted the original topic.  Car is going back to mechanic so he can check 'torque' or the like so will ask him to check over and maybe if I smile nicely he'll waxoil it for me too!  Sometimes it pays to play the ditzy female...(although sometimes I don't have to play at it!)  ;D
