Author Topic: lsd????  (Read 4433 times)
MaLi
lsd????
« Reply #15 on: November 15, 2007, 07:11:19 PM »
Dave.126,
Each diff has some "designed" level of friction, what means that open diff is not realy fully open. This should enable you to start even when one of the wheels is standing on ice covered with thin layer of water (mu ~0.0).
In 126 this friction is achieved by use of thin spacers. If you use too thick spacers you will have more than standard friction. Maybe somebody has made this mistake in your car.
Regards,
Mali
ps. if you're thinking about deliberately using thicker spacers to get kind of a LSD effect, you should know that this will work only limited number of hours  :roll:
