Author Topic: Anyone had their 126 turned over?  (Read 7834 times)
nathan126
« Reply #15 on: September 07, 2007, 09:11:41 PM »
Quote from: "scottisbell"
phreak97
Like the idea of the shock tactic, wouldn't know where to start with that though do you have a wiring diagram?
Nathan, Are you driving yet? I think I remember one of your posts saying you hadn't past your test yet, if your planning on crossing the water give me a shout would be good to get together - shame the southern meet didn't come to light perhaps we could start to organise something else even if it's for next year?
Hey! Nope, not driving yet  :sad:  But i turn 17 in about 15 days so it shouldn't be too long! I havent spent all the time with the car just sitting there though! I've been practising in fields/ car-parks and generally making the car look as good as i can. I'd love to get together in one of the meets sometime, when i get the money to be a paid-up member anyway  :lol:  :lol:
scottisbell
« Reply #16 on: September 07, 2007, 09:31:23 PM »
Hopefully you'll pass your test pretty soon then, you must be well excited!! I was 16 and had a car waiting, a mini, back then that's that what I was into, think you have have made the right choice with a 126 I've had loads of cars, some a bit boring some quite interesting:- the 126 is definitely the most fun to drive (and much better than a mini, I should know I've had 3 mini's and none of them come close to the 126.)
So all being well you might be on the road for a south coast 2008 meet?
« Reply #17 on: September 07, 2007, 09:44:31 PM »
That is really nice, love the colour and graphics.
nathan126
« Reply #18 on: September 07, 2007, 09:48:49 PM »
Yeah, i don't see why not! would be pretty good  :D
Have to see for now though...
« Reply #19 on: September 07, 2007, 10:06:49 PM »
just failed my test so my 126 has to wait even longer to be driven :sad: going to retake shortly tho
nathan126
« Reply #20 on: September 07, 2007, 10:23:27 PM »
ooh, good luck with that! :D
phreak97
  • Niki!
« Reply #21 on: September 08, 2007, 03:10:24 AM »
haha, it's very easy, but requires a little soldering (easy soldering). all you have to do, is geta disposable camera with a flash, take it apart, take the battery out and take a photo with flash turned on before you do anything or itll hurt you, inside the camera there will be either two or three wires attached to the flash bulb, if theres three, get rid of the middle one, you just want the two end ones. disconnect them from the bulb, these go to your shock wires. there will probably be two switches in the camera, one to turn the flash on, and one to take a photo, in my experience the best way is to just solder the terminals so that both the switch and the button are permanently on.
from here, if you want to test it, you can put the battery back in, then wait for the light to come on saying it's ready to "take a photo" then touch the two wires to a piece of kitchen foil, it should blow a couple of little holes in it.
dont keep playing with it by touching metallic objects, personal experience says it overloads the circuit and kills it. human hands wont do that, theres enough resistance. also it wont make burns on your hands like it does to foil, the resistance dulls it down enough to just hurt without causing lasting damage.
after this, it's up to you how you give it 1.5v so you dont have to use a battery. i could probably come up with a regulator circuit or something if you want to do more work, otherwise i recommend getting one of those cigarette lighter adaptors which has a bunch of voltages so you can use portable electronic equipment in the car,  just modify it so it connects to the car battery via a fuse instead.
it all sounds hard in writing, but give it a go, it wont take long at all.
for best effect you probably want either one camera for each wheel arch, or one for each side of the car. the only reason is that once it shocks someone, it takes 10 or 15 seconds to charge up again, and i dont know if it will charge while someone has their hand over the wires.. meaning if two people went to grab a wheel arch each, one would get a shock, and the other wouldnt. another good way might be to have one camera for the front, and one for the back. people will usually just go from one side.
another note, definately put the whole thing in a plastic box of some kind, the board itself can shock you just as easily as the wires coming off it, and  also if the wires coming off touch bare metal they can attach themselves via a weak spot weld:P
also i can vouch that you wouldnt want to put your hand back in there if you got bit by this, i always manage to shock myself making these.
on a legal note, im pretty sure these are just a grey area, i think you are allowed to modify a camera in this way, since it cant actually kill you. using it as a security system in a car might cause frowns from an mot guy though.. probably wanna make it removable.
there are guides online for making a camera stun gun, its the same thing.
i hope nobody gets upset with me for posting this, i almost feel like ill get in trouble.
all it is is a zap, scares the crap out of you, and probably stings for a while. nothing particularly dangerous, but its effective.
phreak97
Tommo32
« Reply #22 on: September 10, 2007, 09:21:59 PM »
Quote from: "ger"
'32 model Y Ford...Not stock....2l Toyota engine, Alfa rear...
in 1932 the ford was a model B. not bocoming the Y untill 1934 i believe, but even then it doesent look like a 34! heres my 32 model B...
Unless yours is some sort of english thing???
ger
    • http://www.dropshots.com/ger
« Reply #23 on: September 10, 2007, 09:49:03 PM »
Yep, Its an English kinda thing....Actually designed in UK, (Despite what it says below), first appeared in '32, scaled up by US and became the US built '34.....
Nice B by the way !
Ger
"The Model Y was the first Ford specifically designed for markets outside the United states of America. The car was powered by a 933 cc, 8 hp Ford Sidevalve engine, and was in production in England from 1932 until 1937, France from 1932 to 1934 and Germany as the Köln from 1933 to 1936. It was available in two and four door versions. The 1935 two door model was the only fully-equipped car ever to sell for just £100 sterling.
Although of American Design, the Model 'Y' took the British market by storm and when it was first introduced it made a major dent in the sales figures of Austin, Morris, Singer, and Hillman. It went on to thrash them soundly by taking over 50% of the 8HP sales.
For the first 14 months the original model with a short radiator grille was produced, this is known as the 'short rad'. After this in October 1933 the 'long rad' Model, with its longer radiator grille and front bumper with the characteristic dip was produced. By gradually improving production efficiency and by simplifying the body design the cost of a Model 'Y' was reduced to £100, making it the cheapest true 4 seater saloon ever. Both 4 door (Fordor) and 2 door (Tudor) saloons were produced and these could be had either with a fixed roof, or the slightly more expensive sliding 'sun' roof.
Gerry
(Near Glasgow, Scotland)
(500 all done MOT'd !)
Tommo32
« Reply #24 on: September 12, 2007, 08:49:03 PM »
nice, i like it! cheers for the informative and interesting responce!
« Reply #25 on: September 13, 2007, 02:49:19 PM »
I recon one of those bike alarms that work where they disable when the ignition is on would be good. They work with a little ball in a box and tilt it a little and the alarm will go-off for I think it is about 1 minute or so.
Oxford alarm I think it be called.
Heathens anyone who would harm a 126!
phreak97
  • Niki!
« Reply #26 on: October 22, 2007, 12:28:12 PM »
i went down to the carpark today after work to find my niki parked about 45 degrees away from the position id parked it in earlier. seems someone decided it didnt look too heavy. interestingly they moved the back of the car, not the front, i guess assuming the engine was in the front, i dunno.
theres no damage, so i guess no harm done.
i park in the pay-parking under my work because i thought it was safer, it costs me $15 a day. im not really happy that this still happened.
how often do 126 owners come out to find thir cars arent quite where they left them?
phreak97
dexter
« Reply #27 on: October 25, 2007, 05:12:04 PM »
not tried to make those stun gun thingys for under the arches yet then!!!!lol  :lol: lol :lol:  lol :lol:  lol :lol:
old people are like slinkys.....not much use but they make you smile when you push them down stairs....
if any one knows to mk2 granada parts please pm me. i have a love for old rusty cars,what ever they are !!!!!!!!!!!!!!!!!!!
phreak97
  • Niki!
« Reply #28 on: October 25, 2007, 11:14:58 PM »
nah, im not gonna do that, i played with those zappers enough when i was younger. im just going with a more or less conventional alarm.
phreak97
Frothy
« Reply #29 on: November 14, 2007, 01:13:13 AM »
I thought you meant flip like this (126 powered NCF Blitz) from http://pages.zoom.co.uk/blitzracing/
I put a fiat panda on it's roof once, the tyre came off the rim whilst I was doing a handbrake turn in a field  :wink:
Frothy
24hp of Mayhem
