Author Topic: Tired of Tyres!  (Read 6108 times)
Tired of Tyres!
« Reply #15 on: August 19, 2007, 08:05:17 PM »
the bolts i used are 12x1.50x40mm are you sure you need 45mm plus did you have the brake shoes fitted to the drums, i had to cut 3mm of the studs because they were clicking/rubbing against the brake shoe and retainer springs. if you get stuck with the bolts PM me and i'll see what i can get locally, as for the brake shoes any motor shop will be able to get them.
