Author Topic: 5 speed bis.................... But we go on to bike engines  (Read 8507 times)
andrewblears
« Reply #15 on: June 05, 2007, 06:10:06 PM »
Id use a v2win and the gear box of the engine THEN RUN A CHAIN FROM THE OUT PUT OF THE BIKE ENGINE GEAR BOX TO THE DIFF ON THE CAR
Or is the dif on the gear box?
Tommo32
« Reply #16 on: June 06, 2007, 08:11:36 PM »
Yeah but the standard diff is inside the gearbox so you would need to stick one in and make some shafts etc, then convert the diff to use a chain which is a ball ache and you end up with an open diff that needs constant greasing.
I too have given this much thought but if i did it i would deffo get shut of the fiat 'box, its crap. and i would fit a hayabusa engine maybe R1, 200bhp has got to be the future. Deffo a massive job to do. I rekkon VW beetle engine + transaxle would be the best.
andrewblears
« Reply #17 on: June 06, 2007, 08:12:19 PM »
:D
Tommo32
« Reply #18 on: June 06, 2007, 08:14:05 PM »
Its an enourmous job, you would need to find a good machine shop to do all the machining. and all that just to stick a V twin engine in. may as well stick to the standard lump unless you are thinging more ducati 996 than moto guzzi.
andrewblears
« Reply #19 on: June 06, 2007, 08:16:27 PM »
Well i have been looking for a chain drive dif from A QUAD BIKE 1000CC Wich will take the harf shafts from the bis but with no look id love to use a harly engine v2win To power it Or mabe the QUAD ENGINE
Tommo32
« Reply #20 on: June 06, 2007, 08:26:08 PM »
hmm, a decent harley lump is at least £1000, then the gearbox is another £800, Im not sure there is even enough room for it in a 126. cant you use somthing which has a gearbox attached to the engine? unless you use a late model twin cam harley engine but you are talking megga bucks there. All big quads are shaft drive, smaller quads with chain drive have no diff. There are companies that make chain driven diffs for racing but they are expensive. then you would have to buy the shafts with it and cut and weld them to your bis shafts. making sure they are true.
Tommo32
« Reply #21 on: June 06, 2007, 08:28:13 PM »
Have you got a link to the 1000cc quad??? that would be awesome. i thought 660 raptors were crazy!!!!
andrewblears
« Reply #22 on: June 06, 2007, 08:30:26 PM »
I may just pop a k&n and a bike exsaust on
Have you looked in to the idia of using a mr 2 engine ?
Tommo32
« Reply #23 on: June 06, 2007, 08:33:33 PM »
nah it would just get way too complex with somthing like that. where to put the radiator etc and its probs too big anyway.
andrewblears
« Reply #24 on: June 06, 2007, 08:35:25 PM »
You have spent a lot of time on this i can tell
toz
« Reply #25 on: June 06, 2007, 08:38:22 PM »
personally i would go for mr2,just would put where the rear seats go,you could put the rad in the front with the tank,you would obviously need to make a cradle and shorten the shafts but it would possibly do it.
andrewblears
« Reply #26 on: June 06, 2007, 08:52:03 PM »
Big arch kit from a mk1 escort For the back mabe
Idle Steve
    • http://www.mb5.co.uk
« Reply #27 on: June 06, 2007, 09:50:08 PM »
Why not stick a GPZ900R engine in?
If you get rid of the passenger seat, do away with the diff?
Take a look at this nutter on you tube :D
http://www.youtube.com/watch?v=6-_Hmjgjn7c
Slight problem with reverse though!!!!!!! :sad:
The wife calls Him "Cecil"
andrewblears
« Reply #28 on: June 06, 2007, 10:50:35 PM »
Reverse can be done with a starter moter i thinck
 A car with no dif is a grate idia for  1/4 mile Simple build to
Love the vid.
