Author Topic: Bis electrical fault  (Read 2137 times)
« on: March 04, 2007, 02:14:39 PM »
Hope someone can help.  My Bis keeps draining the battery in a week!  Have put a multimeter to the battery without the ignition switched on and I get a reading of 0.18A so there is a drain.  If I remove the Radiator fan fuse the reading drops to 0.07, then if I remove the radiator fan relay it goes to 0.  I have tested the relay and this is ok.  I have fitted a new two stage switch so I assume it is not this.  Also I know that when the engine is hot the fan can still operate after the ignition is switched off but I would of thought that this would shut down after the engine has cooled down.  So where could the problem lie?
Thanks for your help!
