Author Topic: Wheel allignment pins  (Read 2654 times)
« on: February 04, 2007, 12:29:27 PM »
Hi following on from alloy wheels part 2, added pics now on that thread.
To get my spacers to fit I have removed the small allignment pins on the rear wheel.  Is this OK?  My wheel won't fall off will it?
Now spacer if fitted wheel no longer rubs!
« Reply #1 on: February 04, 2007, 12:45:15 PM »
no your ok,the pins are there for in the dark wheel changing....but,make sure your wheel bolts are long enough to cope with the spacers eh????
« Reply #2 on: February 04, 2007, 01:05:17 PM »
spacers are 5mm, original wheel bolts still fit, is this OK?
Cheers for all your help
« Reply #3 on: February 04, 2007, 01:13:51 PM »
Bruce
« Reply #4 on: February 06, 2007, 12:04:27 AM »
i've got original wheel bolts on my alloys, but i would not want to risk it with spacers on
« Reply #5 on: February 06, 2007, 07:32:52 AM »
my rims are slightly wider than standard at the hub,i would say around the 5mm mark,i've had no problem with hub bolts coming loose etc,and i really push my car hard,just make sure you check regulary for the first 1000 miles as the wheels bed in to the hubs/drums.....im not condoning or saying your safe tho,thats your choice!!!!...
oh,and dont forget ''copperslip'' or something on the back of the alloy wheel.........thats stops the wheel corroding to the steel/iron hub.
your rims do seem to have lots of inset,defo ex FWD ones
