hi,you could try checking the earthing of the starter motor,also,both my bis have suffered from oil contamination of the starter motor due to gearbox input shaft seal problems,this knackerd both good starters,they would work with an exter jump tho.....and it also bolloxed both clutches :shock: ............hope you've just got earth problem or suchlike.........
