Author Topic: gear box mountings ??  (Read 2802 times)
mattlucas
    • http://www.nulifeglass.com
« on: November 23, 2006, 01:23:31 PM »
does anybody know if gearbox mountings for a 126 bis are the same as fiat 500 models im going to order them from ital corsa and they seem to think they are the same but just need to make sure many thanks
matt
« Reply #1 on: November 23, 2006, 02:17:16 PM »
nope they are differnt on the BIS mate
www.fiat500126.com have a look here it shows you a pic of Bis mounts
regards
mattlucas
« Reply #2 on: November 23, 2006, 02:52:47 PM »
thanks especially for your patience with my knowlege .....and spelling
« Reply #3 on: November 23, 2006, 04:49:14 PM »
you need left side and right side, MOT failiure if worn
how come you need to replace them? have yours perished?
regards
mattlucas
« Reply #4 on: November 23, 2006, 05:47:59 PM »
they are so perrished half of its missing so the  total 126 amount of money spent this week £150 im getting them from auto rosa in hampshire very helpfull
« Reply #5 on: November 23, 2006, 07:25:34 PM »
they do break,especialy if the last driver was a savage.........matt,make sure you give the 'box and engine an oil change asap(and remove the filler plug before draining).......and dont forget the oil filter........99% chance it will never have been cleaned......
mattlucas
« Reply #6 on: December 12, 2006, 01:30:19 AM »
dont mean to sound stupid but i cant find the oil filter and just got a new one and a fuel filter but cant see one there shall i just put it in a sutable place along the fuel line?
« Reply #7 on: December 12, 2006, 11:26:25 AM »
place your fuel filter before the fuel pump that way no rubbish will get to the pump. your oil filter is not like the norm. if you look at the alternator you will see a belt connected to another pulley this pulley houses the centrifugal oil filter to access this filter you must first place a jack under the engine and take the weight off the engine mount.disconnct the three electrical connectors for the reverse fog and no plate lights, then undo the bolts that hold the rear panel on the panel and bumper will come off . you can then undo the ring of 10mm bolts that hold the filter on. simply clean out all the crud inside and make sure you replace the gasket (big o ring)when you reassemble. you can do this without changing the oil but can be a little messy plug the hole where the oil seeps out for less mess. to be honest if you are going to do this job change your oil at the same time (obviously empty with oil hot before the cleaning of the filter).
