Author Topic: Help-No spark  (Read 2315 times)
fsmlittler
Help-No spark
« on: October 19, 2006, 08:49:25 PM »
I've just recently finished installing my nice shiny new 126 engine and gearbox in my 500 and have managed the huge distance of 5 miles before my first breakdown. I went out this morning and the car just stopped after half a mile and now refuses to start. On checking I have no spark whatsoever. I've rechecked the points and the timing hasn't changed so I suspect the new coil-the square wasted spark type. Any idea how to check or whether it's something else?
Help-No spark
« Reply #1 on: October 19, 2006, 09:42:06 PM »
just a thought. Did you fit a ballast resistor to the coil?
fsmlittler
Help-No spark
« Reply #2 on: October 19, 2006, 10:52:52 PM »
No but I thought that tended to make a longer term difference to points and plugs rather than the coil and surely it wouldn't go down after 4-5 miles without one?
Help-No spark
« Reply #3 on: October 20, 2006, 03:52:18 PM »
Usually with ballast resistor coils, they are designed to run at a lower voltage something like 6-9v. If there is no ballast resistor in circuit the coil runs at 12-13v, it can then cause damage to the ignition components.
