When I removed the sump plug I found it had been glued in place, and it was soon clear that this was because the thread has been stripped by some gorilla in the past.
The plug's measurements are exterior diameter=22m, thread pitch 1.5mm. This looks like metric 22mm (M22 fine, or very fine depending on whose terminology you use).
My plan is to phone around to find a garage who can die-cut and fit a helicoil. Doing this myself sounds a bit scary. I considered getting a self-tapping tapered plug, but that sounded ugly. I don't want to glue it again.
How to I unambiguously specify the thread?
Is a helicoil a good plan?
Are ther other options?
Thanks,
Bill (Bristol)
