Author Topic: Full beam headlight switch not working  (Read 1686 times)
Iffy650
« on: June 30, 2025, 02:45:42 PM »
Full beam switch not working up & down, but does come when pulled slightly towards steering wheel
ronb1967
Re: Full beam headlight switch not working
« Reply #1 on: August 02, 2025, 08:58:09 PM »
Hi have you cured it since , sounds like a dirty contact in the high beam stalk , im sure mine was the same , you had to pull really hard towards steering wheel to get the headlights to flash
Iffy650
« Reply #2 on: October 01, 2025, 05:20:56 AM »
Thanks ronb,
Yes, it was actually my ignition switch that was faulty (plastic brittle, fell apart during disassembly!). Had to buy a new ignition switch & low/full beam working now
