Author Topic: Slight Fuel Leak to Carburettor Base & Engine Dies when using accelerator  (Read 1377 times)
0 Members and 4 Guests are viewing this topic.
Iffy650
Air cooled 1989, 650 cc
Fitted a reconditioned carburettor with new needle valve and float.
Runs well on choke but dies when I use the accelerator.
Got a leak of fuel into the carburettor base.
Suggestions of how to fix welcomed.
Sounds like a main jet issue.
Perhaps there is debris or rust in the fuel system? Do you have an inline fuel filter? also worth checking the float is set to the right height.
Iffy650
Thanks Chris, I'll check that
Iffy650
Hi Chris,
I unscrewed the main jet nozzle from the bowl, cleaned it out. I set the float height and the engine runs fine now, however I'm still getting a small amount of fuel leaking into the plastic base (directly below the carb). Looks like it's coming through the gasket between the carb cover and main part of the carb.
Do you have any suggestions about how to stop that leak?
