Author Topic: Remanufactured Weber 28 IMG Carb  (Read 1540 times)
Iffy650
« on: May 08, 2022, 01:49:41 PM »
I think about replacing my Weber carb as it is leaking at the base. The base has worn & even leaks with new gasket.
Has anyone bought a remanufactured carb, is it worth the saving in price compared to a genuine weber carb?
Anyone bought parts from Racambi Fiat in Wroclaw , Poland?
bertvb
Re: Remanufactured Weber 28 IMG Carb
« Reply #1 on: May 08, 2022, 09:33:15 PM »
The base can't be fixed?
I've used a file to re-do the base surface of the carb, since mine was a bit bend. This solved my problems.
Iffy650
« Reply #2 on: May 09, 2022, 11:41:27 AM »
Thanks bertvb, my base was worn due the previous air leak so I filed it as flat as I could and used a silicone gasket but it's leaking again.
