Author Topic: Seating Rear suspension spring  (Read 1544 times)
jerrymet62
« on: November 17, 2021, 02:08:22 PM »
Hello
I am replacing rear springs.
Is there a position the bottom end of spring should sit in the frame?
Also the manual mentions insulators yet from all the drawings, pictures I have seen & indeed on the spring removed there only appears to be a top one.
I am a complete novice & any advice would me much appreciated.
Regards
Jerry
andyzeetec
  • 126 BIS
Re: Seating Rear suspension spring
« Reply #1 on: November 18, 2021, 12:50:11 PM »
I would be interested to see the answer on the fitting position at the bottom.
Like you say there only seems to be an insulator at the top,  https://www.ricambio.co.uk/rear-coil-spring-rubber-seat-classic-fiat-500-126
There are some good pics here of the BIS rear suspension  http://club126uk.co.uk/club126uk/forum/index.php?topic=10831.0
« Last Edit: November 18, 2021, 01:07:55 PM by andyzeetec »
« Reply #2 on: November 18, 2021, 01:03:52 PM »
There are two insulators on the Bis, not sure if the air cooled is the same?
jerrymet62
« Reply #3 on: November 18, 2021, 01:53:31 PM »
Here's a pic of air cooled.
No bottom one
jerrymet62
« Reply #4 on: November 18, 2021, 01:55:54 PM »
I ended up rotating until it sat evenly but no clear locking of bottom end of spring.
I will take a picture when i do other side.
