Author Topic: 126 tank sender resistance range  (Read 1915 times)
jacw
« on: August 14, 2021, 05:36:36 PM »
Help please can anyone let me know what the 126 tank sender resistance range is?
I did have a trawl through prior postings with no success.
Many Thanks
jacw
2bisornot2bis
Re: 126 tank sender resistance range
« Reply #1 on: August 15, 2021, 04:05:05 PM »
From an old sender from a 126 BIS fuel tank I measured the resistance as about 420 ohms over the total length.
The swept resistance measured from the sensor connector to the float arm (earth) is 25 ohms to 350 ohms (full to empty stops).
Hope this helps.
That is the question.
jacw
« Reply #2 on: August 15, 2021, 09:31:04 PM »
That's perfect, thank you very much for getting that info for me. I can now program my new fuel gauge.
Best Wishes, jacw
