Author Topic: Bis Vacuum advance pipe, where to connect?  (Read 1270 times)
elanman99
« on: May 14, 2021, 08:19:18 PM »
I've searched previous threads and looked at the picture in the workshop manual CD but I'm still confused as to which stub the vacuum hose should be connected to.
There is a brass fitting in the aluminium manifold and also one on the RH side of the carburettor (30DGF), which should be piped to the distributor?
Ian
Located in Sunny Sandiway
