Author Topic: RHD speedo cable query  (Read 2124 times)
Minijohn
« on: November 15, 2020, 03:28:21 PM »
I'm in the process of converting my LHD car to RHD. I've fitted a new speedo cable which at the moment emerges from the tunnel near the pedals.
Could someone with a RHD car tell me where it comes through the bulkhead into the front boot?
I don't want to drill a hole and then find it's in the wrong place.
Photos would be ideal
Thanks in advance
« Last Edit: November 15, 2020, 03:38:17 PM by Minijohn »
Macmonkey
Re: RHD speedo cable query
« Reply #1 on: December 03, 2020, 02:21:35 PM »
Hello. Are you still after dimensions/pictures for this? Only I am changing the Speedo cable in my rhd car this weekend so could take some pictures if you need them.
Minijohn
« Reply #2 on: December 03, 2020, 05:55:03 PM »
Thanks for the offer but I've sorted it.
I drilled a hole near the pedals so the speedo cable takes a gentle curve up/round to the speedo - seems to work fine
« Reply #3 on: December 03, 2020, 08:56:03 PM »
Still be great to add some photos and measurements in case someone else gets a similar problem.
Macmonkey
« Reply #4 on: December 07, 2020, 07:33:32 PM »
Speedometer Cable Layout. The hole in the boot is 20mm. Hope this is of some use to someone, any questions shout up.
« Last Edit: December 07, 2020, 08:07:48 PM by Macmonkey »
Minijohn
« Reply #5 on: December 07, 2020, 11:10:06 PM »
That is useful - I would never have imagined that's the route it took.
