Author Topic: BIS crankshaft end float asjustment  (Read 1719 times)
Guldbergdk
« on: January 17, 2020, 10:34:56 AM »
I pulled my BIS engine apart, glassblasted it and serviced all parts.
Crankshaft bearings were shot, so I exhanged those.
I did however forget to look at the crankshaft float before I disassembled it. How are the crankshaft hold in place? Right now there are some 2mm float :-) From the exploded view and the workshop manuals I cannot figure out how its fixed. Is it suppose to ride against the flywheel end or the timing chain end?
Re: BIS crankshaft end float asjustment
« Reply #1 on: January 17, 2020, 03:10:34 PM »
It sounds like you may have put the thrust washer in the front bearing the wrong way round as circled, the hole in the centre has a chamfer, which mates with the chamfer on the crank if its the wrong way round it will give you 2/3 mm float
Guldbergdk
« Reply #2 on: January 21, 2020, 08:34:23 AM »
Thx.
I hadn't mounted the washer yet. I forgot was I was looking for and misplaced in a box. Once I found it, it was pretty obvious:)
« Reply #3 on: January 21, 2020, 08:17:58 PM »
That's good news, I did it myself many years ago and spent a week scratching my head :headscratch: 🙂
