Author Topic: Clutch cable position  (Read 1640 times)
nalonso
« on: October 17, 2019, 04:07:07 PM »
Hi fellows!
I need some advice: The clutch arm at the gearbox has two holes, one for the spring and one for the cable. Could someone tell me what goes in the hole near the gearbox? In my 126p aircooled, the spring is in the closest hole, and the cable is touching the body in the rear suspension arm base. Should I change the cable to the closest hole? I checked the manual and the picture is not clear in this aspect.
Thanks in advance!
All the best,
Nestor
nalonso
Re: Clutch cable position
« Reply #1 on: October 17, 2019, 04:41:56 PM »
Well, checking the Haynes I found a picture for that... The spring goes in the nearest hole to the gearbox. I don't know how to solve the cable touching the body... Is this normal?
