Author Topic: Engine mounts?  (Read 3450 times)
126redbomb
Engine mounts?
« on: August 22, 2019, 04:23:54 PM »
Hello all. Can someone tell me what these are called, only I have looked on Ebay and I can't see any that look anything like it. I don't know if the photos will load...
Regards Colin
Xylaquin
Re: Engine mounts?
« Reply #1 on: August 22, 2019, 05:57:59 PM »
gearbox mounts, unique to the BIS. They're a bit rare and as a result sellers charge a pretty penny. Fiat Fischer currently has a pair in stock:
https://www.fiat500-fischer.de/epages/es322159.sf/en_GB/?ObjectPath=/Shops/es322159/Products/31104
Re: Engine mounts?
« Reply #2 on: August 22, 2019, 09:24:17 PM »
 Axel Gerstl is a bit cheaper, unfortunately they haven't got any in stock.
 https://webshop.fiat500126.com/en/rubber-parts-und-hoses/engine-und-carburetor/transmission-bearing-rubber-piece-right
 Looks like Ricambio doesn't have any in stock either.
 Maybe ask Piotross on the forum.
« Last Edit: August 22, 2019, 09:29:18 PM by 1973/126 »
Piotross
Re: Engine mounts?
« Reply #3 on: August 22, 2019, 09:35:20 PM »
They are unique parts even in Poland and completely unavailable
DEYAN IYI
Re: Engine mounts?
« Reply #4 on: August 22, 2019, 10:08:16 PM »
It can be custom refurbished. There are workshops specialized in this kind of favours. It is a bit more expensive if they don't have the mold for the model.
126redbomb
Re: Engine mounts?
« Reply #5 on: August 22, 2019, 10:15:47 PM »
Thanks guys for your quick replies. Yes it rhymes  ::).
If I can't find them I suppose that's what I will have to do. There is a unit near Birmingham airport that does CV joints, so fingers crossed they might be able to make some.
Regards Colin
126redbomb
Re: Engine mounts?
« Reply #6 on: September 15, 2019, 04:59:36 PM »
Oh well I placed an order with fischer but they cancelled it during the week without explanation :$   I have emailed them and hopefully I can re-.order them.
Fingers crossed
Ricksy1121
Re: Engine mounts?
« Reply #7 on: September 15, 2019, 05:13:38 PM »
Iv seen a post somewhere, possibly piston heads forum. The lad filled them with black sticker flex/windscreen sealent to stiffen them up. Could be worth a try if your needing new ones anyway.
Re: Engine mounts?
« Reply #8 on: September 16, 2019, 04:28:40 PM »
I'm pretty sure I have some. I bought a bis box for my aircooled. No use to me Ill have a look in the garage tomorow
Re: Engine mounts?
« Reply #9 on: September 16, 2019, 06:54:01 PM »
Has anybody ever measured the size of bush that would be required to recon the original mounts as this has been a recurring theme?  Have had a similar problem with the rear top shock absorber mount on a Fiat Panda Cross. The bush seems to be designed not too last and you cannot buy a replacement , you have to buy the whole shock so after initially having to buy a new set as time was not on my side I now recon one set whilst the other set is fitted then change pre MOT if required. I have either repaired originals, re cast my own poly bushes, found poly bushes I can modify or modified other bushes.
126redbomb
Re: Engine mounts?
« Reply #10 on: September 16, 2019, 08:54:37 PM »
Cheers dajwid
I will contact you later when I get home.
 :thumbup
126redbomb
Re: Engine mounts?
« Reply #11 on: September 19, 2019, 12:18:24 AM »
Hello Dajwid, did you manage to find any?
126redbomb
Re: Engine mounts?
« Reply #12 on: September 29, 2019, 08:50:55 PM »
I contacted Fischer about my order which for some unknown reason didn't get delivered or should say got sent back  :cry: I have reordered the mounts so hopefully this time they should arrive. Fingers crossed
