Author Topic: Hello from the Shire (Gloucestershire)  (Read 5627 times)
johnvine
Re: Hello from the Shire (Gloucestershire)
« Reply #15 on: August 19, 2017, 05:17:31 PM »
Hello Adeyspec. I have just finished a rebuild on my 126bis that had not run for 20 years. Among the many things wrong were the gearbox mounts. The metal was ok but the rubber bonding wasn`t !From what I could gather they are handed but mine were both the same. As they are very dear I used a 2 pack polyurethane from Bentley chemicals having shot blasted the metal to get a good bond. The rear mount is very difficult to install. It is hard to get the bolt to go into the captive nut. I have done mine twice because Ricambio supplied the wrong clutch driven plate. (They are usually very reliable.) If you need the black window trims/weatherstrips you will find that the repro. ones are useless. I would like to hear from another 126 owner, in spite of being in the club I have had very little contact. Give me a call if you like on 01562 747718 (Kidderminster) Regards John
