Author Topic: Steering column electricals removal  (Read 2390 times)
Fat650
« on: January 22, 2017, 01:56:51 AM »
Anyone know how to remove the electricals off the steering column?
I dont fancy breaking any of it to get it off.
Xylaquin
Re: Steering column electricals removal
« Reply #1 on: January 22, 2017, 03:45:04 AM »
If it's a BIS, the connections can usually be found if you remove the air intake grill on the driver's side. Unplug the steering from the loom and then push the connectors through the hole into the cabin.
Fat650
« Reply #2 on: January 23, 2017, 11:48:09 AM »
No, i have an 88 niki.
I mean the black bit on the steering column with the blinkers and windscreen washer levers.
DeVilleChris
    • Club 126 UK
« Reply #3 on: January 23, 2017, 01:53:59 PM »
on my 1979, its a single plug into the loom.
Unbold the wheel, slide it off, then the stalks just slide off and unplug.
When refitting I'd recommend cleaning the contacts cause they do fail some times..
1979 Fiat 126 DeVille
1979 Fiat 900T Amigo
Fat650
« Reply #4 on: January 23, 2017, 07:59:55 PM »
I tried to pull it off but it didnt seem to want to move. Might give it another go
« Reply #5 on: January 27, 2017, 02:28:51 PM »
You may have to undo the cowling bolts. I think the loom may attach to one of the studs.
