Author Topic: What 13inch wheels to fit over abarth disk brake conversion for rear?  (Read 10416 times)
Marco126
Re: What 13inch wheels to fit over abarth disk brake conversion for rear?
« Reply #15 on: January 10, 2017, 02:41:18 PM »
Hi, my wheels don't rub on full lock.
Fat650
« Reply #16 on: January 16, 2017, 09:18:26 AM »
Do you know if you can go any wider if you could get the right tyres?
Fat650
« Reply #17 on: January 18, 2017, 08:01:49 AM »
Also, would you have an other pics that show the clearance you have near your shocks and inner guards?
Fat650
« Reply #18 on: January 19, 2017, 12:53:26 AM »
I have a set of rear callipers from an FSO/X19 I think, with addapor plates that fit 13" wheels. Unfortunately not fitted at present. I am thinking of just upgrading the wheel cylinders with ones off the front, these have a larger piston diameter, this is a suggestion Gadge came up with and it should provide greater breaking at the rear without the potential of locking up prematurely. It also removes the need for adapters, modified cables and pressure valves.
What adaptor plates are you using?  Are they the general ones everyone seems to sell?
Marco126
« Reply #19 on: January 19, 2017, 07:12:17 AM »
I'll take some pictures for you over the weekend if not before
Marco126
« Reply #20 on: January 20, 2017, 02:00:18 PM »
Hi, you can see my calibrated fingers stuck between the wheel and the shock. There is at least an inch of space. I'll get you pics of it on full lock and the rears tomorrow.
Marc
Fat650
« Reply #21 on: January 23, 2017, 11:51:40 AM »
Marc
No way coilovers would fit with those wheels! Haha
sunriser81
« Reply #22 on: January 26, 2017, 07:44:55 PM »
Hi what type of calipers are available in Australia. I can cut conversion plaste for any calipers if thats helps...
Fat650
« Reply #23 on: January 26, 2017, 11:38:17 PM »
Do you do ones for X1/9?
