Author Topic: Seat belts  (Read 1835 times)
Early126
Seat belts
« on: May 08, 2016, 08:21:49 AM »
Hi all.
I'd like to fit rear seat belts in my car as there are currently none. Are there threaded fixings from the factory that I need to locate in the body ? Pictures of rear seat belts would be appreciated.  I've seen some belts on ebay for about £50 and want to see others 126 rear belts to see if they are the same.
Ta.
Bar Vitelli
Re: Seat belts
« Reply #1 on: May 08, 2016, 08:26:18 AM »
The original seat belts for your car should be Britax seat belts. If you PM me your e-mail address I can send you some pictures.  ;D
Every cloud has one...
Yoshimisumi
Seat belts
« Reply #2 on: May 08, 2016, 04:50:30 PM »
My 89 126p had fixing points already in place - you can see the lap belt points under the seat squab and by taking out the rear arch liners which helps as they may need a bit of cleaning out. Didn't got for full inertia belts so not sure about the tops.
Early126
Re: Seat belts
« Reply #3 on: May 09, 2016, 07:55:36 AM »
That would be ace, its [email protected]
