Author Topic: MCA Spider  (Read 18740 times)
amam
Re: MCA Spider
« Reply #15 on: June 22, 2016, 07:58:11 PM »
both seats now fitted  :D
gotta think about making some door cards now
« Last Edit: June 23, 2016, 08:48:57 AM by amam »
Re: MCA Spider
« Reply #16 on: June 28, 2016, 10:19:00 AM »
 I think we can safely say, you are doing slightly better than me  :P Looking good so far.
amam
Re: MCA Spider
« Reply #17 on: June 30, 2016, 07:20:08 PM »
ah well hes a update
decided i'd convert the kit car to the SU 1 1/4 carb as i know it very well, i bought the manifold to allow it to fit
to fit the manifold you have to undo two of the head nuts and screw the studs on, then the manifold slides down them and you use one bolt at the back too.........well thats whats suppost to happen
it was a huge pain to fit the manifold, i ended up hoaning out the holes because they didnt quite line up with the studs and then i had to do the same with the rear hole.......then i had to grind down the back edge as it hit the rocker cover not allowing the manifold to sit flat.....
manifold fitted
got a carb, a early SU without the breather as it won't be needed, just test fitting it, removed the original throttle linkage, just waiting for parts to rebuild the carb
next pain in the ar*e was the thermostat, ive never seen the flap open since ive got it, removed the tin ware
then found out my thermostat was a all in one version which i guess it what was originally fitted! also trying to get the rod off it broke......so ive now bought a thermostat plate, new rod and nut for it....just got to wait for them to arrive now
so heres the update and none of the jobs i started ive managed to finish yet........great........lol
« Last Edit: June 30, 2016, 09:33:46 PM by amam »
amam
Re: MCA Spider
« Reply #18 on: July 05, 2016, 07:09:19 PM »
new thermostat and fitting plate all together on tin ware now
SU carb all fitted now, runs lovely on it too
« Last Edit: October 08, 2016, 03:19:56 PM by amam »
Re: MCA Spider
« Reply #19 on: July 05, 2016, 08:59:12 PM »
Looking Sweet Amam  :good:
amam
Re: MCA Spider
« Reply #20 on: July 23, 2016, 04:26:03 PM »
just some more updates, the car has a proper throttle linkage made now for the SU carb, all works very well
also i made some door cards which look better than i expected
also ive renewed the front suspension, new spring, new wishbones, new backplates, shocks and uprights
« Last Edit: October 08, 2016, 03:20:30 PM by amam »
Re: MCA Spider
« Reply #21 on: July 23, 2016, 10:39:57 PM »
Lovin it :)  can't be too far away now
amam
Re: MCA Spider
« Reply #22 on: August 22, 2016, 08:59:32 PM »
well i had a change of heart and ended up with this
which of course meant i needed these  :D
not forgetting the spare!
safety first
also made a little joiner for the SU carb so it goes with the original air filter
just on with the back brakes now, changing both rear back plates as they were rotten
thats all for now, its coming on a treat
1300ot
Re: MCA Spider
« Reply #23 on: September 27, 2016, 09:02:22 PM »
Great stuff amam.  Nice to see another MCA being rebuilt.   I'm also fitting a similar inlet manifold so hoping mine will be easier!
amam
Re: MCA Spider
« Reply #24 on: October 07, 2016, 04:11:40 PM »
lots happened haven't posted much..........so here it all is in whatever order lol
some lovely new rear brakes, new cylinders, shoes and springs
new fiat uno master cylinder to match my disc brakes
interior now finished, red steering wheel now to match along with switches for the reversing lights and fog lamps with illuminating lights, chrome ash tray and a spider decal, matching red sun visors too
my switches :)
and also ive added some rear wheel spacers so the alloys dont rub on the body anymore but more noticable is the 1980s style decals
next on the list is to get a hood made
« Last Edit: October 07, 2016, 04:18:08 PM by amam »
drcdb15
Re: MCA Spider
« Reply #25 on: October 07, 2016, 07:12:32 PM »
Can I be the first to congratulate you on what looks to be the most rapid and stonkingly superb resto I can recall seeing. I take my hat off to you (well, I would if I wore one), I don't know how you got such rapid progress and still kept doing the day job - unless restoring this little gem *is* your day job!
Well done, and lots of photos please for the 2017 126 calendar!
Re: MCA Spider
« Reply #26 on: October 08, 2016, 09:31:57 AM »
Excellent work! it looks fantastic! :D I'ld love to see this in the flesh. Outstanding work :thumbup
amam
Re: MCA Spider
« Reply #27 on: October 08, 2016, 05:08:53 PM »
thank you for your kind words, there is plenty to do yet such as get a convertible roof made, tidy up the wiring room and fix a few rough edges, the car has been done in late afternoons and the odd free days during this summer, surprised myself how fast ive done most of it but ive not skipped on the quality of parts ive bought
ive just re-added alot of photos since alot had gone missing from this thread
amam
Re: MCA Spider
« Reply #28 on: October 08, 2016, 05:10:30 PM »
love to see some more pictures of your coupe, only saw the ones on ebay, i did love it when it was originally in that bluey turquoise colour
amam
Re: MCA Spider
« Reply #29 on: October 12, 2016, 02:45:50 PM »
couple of nicer shots as i was moving it
first week in November it is now booked in for its convertible roof fitting and side screens
