hi
Fiat 126 has two places where it is necessary to check the connection weight
1. the back of the left side of the engine to the body goes flat without plastic cable guard. Pay attention to the condition of the cable and the connection is not dirty.
2. The front of the car, from the battery to the car body goes short cable may require attention
From my own experience and knowledge of this model fiat I know the dynamo which was installed is not efficient. For this reason, fiat applied alternator. if it is still a dynamo I recommend replacement alternator for easier access to parts
recommend charging to check the meter, it is very simple
To connect the battery meter plus the clamp plus, minus to minus clamp
start the engine and turns at 2000 / min
the meter must indicate 13.7-14.5 V if it is more than 14.6V that is, the voltage regulator is to be replaced.
if it is less than 13.5V to brush exchange
