Author Topic: interior panels and engine fired!  (Read 213456 times)
Stuey's 126-wheels centres arrived!
« Reply #105 on: May 28, 2008, 12:20:34 AM »
Wery nice, i watched the video a dozen times just amased...  :wink:
but how do we know there isnt a little man isnide opening the doors...  :smt043  :smt043  :smt031  :D  :D
« Reply #106 on: May 29, 2008, 02:53:25 PM »
no midgets on my watch sir..... :wink:
Pawel83
« Reply #107 on: May 29, 2008, 11:05:37 PM »
:shock: You must have a lot of free time. Show some pics of the interior  :wink:
« Reply #108 on: May 30, 2008, 12:21:04 AM »
Do a little movie about the boot, wanna see how that looks.
p.s. did you make those solenids yourself, or is it a kit you installed?
nrg19uk
i
« Reply #109 on: May 30, 2008, 02:37:00 PM »
i know maplins do a kit for about 35 pounds last time i looked.
Neil gargaro
« Reply #110 on: June 02, 2008, 12:10:56 PM »
its a central locking kit from ebay think it was about £20 I merely attached the solenoids to the wire for the interior door pulls- the trick is getting the tension correct - too much and the doors wont latch, not enough and the door wont open..
the boot one is very simple- just weld the bracket to the side of lock- drill a hole for the acuting rod though the top of the lock then just mount it wire it (sepreate switch or off the old wiper wiring like i did) hours work tops
if you guys want pics of what went where just ask and I will post some, Ive done all the hard stuff and made the mistakes ( 2 burnt out solenoids) so you dont have to!  :wink:
« Reply #111 on: June 02, 2008, 02:01:08 PM »
Show off!!, cmon give us those pics.
p.s. do you have to remove the locks, cos i dont want to repaint my whole car just so my doors can pop out...  :D
« Reply #112 on: June 02, 2008, 03:08:37 PM »
nope you can do this and leave all the existing stuff in place, ill sort some pics tonight as Im currently at work....
« Reply #113 on: June 02, 2008, 03:12:03 PM »
:smt023
« Reply #114 on: June 04, 2008, 04:01:04 PM »
sorry guys havent got around to the pics of the solenoids (tommorrow i promise) but i have been doing this-
On a recent (illicit) test drive I managed to smash the front wheel into the wing  >:(..
so to fix this issue and to give the stance a more consistant look I needed to dial in some negative camber at the front, the method has been done before but not really picture documented but it basically goes like this-
take a standard 126 top arm-
create a cardboard template to allow you to know the location of the original bolt centre -
them measure over 9mm for the new one-
drill a guide hole using the template-
then weld up the old one and drill out the full size new one-
and fit to car-
here a pic of the side i hadnt done at that point for comparison-
heres a couple of the pics with both sides done-
« Reply #115 on: June 11, 2008, 08:55:31 PM »
I had mine like that a while back, steering went harder and didn't really notice much diference in handling.
What have you found?
Tomasz
« Reply #116 on: June 13, 2008, 01:20:58 PM »
Looks great, thanks for posting the pics, its really useful.  I may be thinking about doing this when i have the time.
By the way i didnt call because they had already done half the spraying on the mg when i got back from work!
Darrell:  did you go about the neg camber in the same way?  If so do you have the modded top arms spare as that would save me some time.
« Reply #117 on: June 16, 2008, 10:56:43 PM »
last few bits today and tomorow- did all the seam sealing and undersealing today then sorted the cathode tube for the numberplate light- i used some box section and welded some threaded round blocks to mount it to the bumper and incorperated the plate mounts to it as well-
 I cut a hole to let the light out then simply slid the cathode tube up the box section et voila! (night time test was to satisfy me it was bright enough!
« Reply #118 on: June 18, 2008, 08:24:43 PM »
Funny thing was that the camber on mine went out alot after changing the king pins things.
I got some reconditioned ones from *a company near london that sells fiat spares beginning with R*
The camber change was dramatic but I drove it for a bit and the steering went quite a bit harder.
« Reply #119 on: June 19, 2008, 01:03:43 AM »
Quote from: "Darrell"
LOL, thats funny...  :D  :D  :P
