Author Topic: Bis erratic running  (Read 10653 times)
mintex
Re: Bis erratic running
« Reply #15 on: January 17, 2016, 06:06:25 PM »
Is this accelerator pump easy to fix and where do I get one from?
I've taken some pictures and done a small video for you to see what yours should do.
If you work the throttle with the engine off and look in the carb you should see it squirting a small jet of fuel in.
As dadandlad said if yours isn't working it might be blocked or need a new diaphram in the pump located on the carb.
Hope it helps a little  :)
[youtube]https://www.youtube.com/watch?v=GEs1MS--GJw[/youtube]
« Last Edit: January 17, 2016, 06:09:52 PM by mintex »
Dave
« Reply #16 on: January 17, 2016, 08:05:54 PM »
Thanks Dave for the photos I'm sure they will help other members :thumbup
Bambino126
« Reply #17 on: January 17, 2016, 10:27:37 PM »
Thanks both of you I will check that out, the pictures explain it all  :thumbup
dadandlad
« Reply #18 on: January 18, 2016, 08:12:55 PM »
Well the plot thickens
Checked the valve clearances as per Petes idea to no avail all found to be correct
Accelerator pump working fine
Ordered a Ultrasonic cleaner from ebay and going to fully strip carb once again
mintex
« Reply #19 on: January 18, 2016, 08:31:31 PM »
Bit of a strange one? Will it go on full throttle or are you still running it in?
Dave
dadandlad
« Reply #20 on: January 18, 2016, 08:43:15 PM »
Still running it in but I have opened it up on to the second choke but not to the stop, so long as you give it chance to catch up it revs fine
I will keep plugging away at it
dadandlad
« Reply #21 on: January 18, 2016, 09:55:15 PM »
I have asked on Retro Rides for help and in doing so could have stumbled on the answer
When I originally stripped the carb it had sat for years full of gunk
The accelerator pump jet was blocked solid and nothing I did would clear it, so I got online and found a shop selling said jet.
The original jet didn't  have  a size marked on it so I wrongly or rightly assumed one size fits all
Opinion seems to think it is running rich, made even worse by giving it a little choke
I have found a company selling the correct jet so hopefully this will cure it fingers crossed
If it cures it I will be kicking my own backside for a month
dadandlad
« Reply #22 on: January 21, 2016, 11:14:41 PM »
Well the carb is off again and in lots of bits
I managed to find some info on the Weber 30 DGF online but fitted to a Panda 30 and it appears I have the correct size accelerator pump jet fitted
What I did notice though was the very low fuel level in the float bowl approx 6mm deep barely covering the two jets in the bottom
I have also purchased a Ultrasonic cleaning tank and had the carb in and cooking
I will post some pictures of the carb before and after so you can see the results
Should have the carb back on tomorrow night
dadandlad
« Reply #23 on: January 22, 2016, 09:37:40 PM »
I didn't get chance to refit the Carb this evening but have rebuilt it once more
I did find a issue with it and if it works all will be revealed tomorrow
dadandlad
« Reply #24 on: January 23, 2016, 05:59:54 PM »
Well where to start
Today refitted rebuilt carb and if anything its worse  :cry:
Well I decided to start right from the very basics
Removed rear panel and bumper and stripped off timing cover to check timing of crank to camshaft all found to be correct so everything refitted
Checked valve clearances all found to be correct
Removed and examined spark plugs found to be very sooty
Started her up and checked timing again
For some very annoying reason it now runs and revs fine with only a very very slight hesitation when opening the throttle
It is so annoying that I dont know what the problem was
One thing I think is worth mentioning which I could see someone else falling into the trap of doing is
The big jet just to the right of the accelerator pump has a tapered seat which I can only assume seats internally, now if you do as I did and replace the O-ring with a copper washer the jet will not seat internally as in effect the washers jack it out slightly
What if any effect this would have I dont know
mintex
« Reply #25 on: January 23, 2016, 08:16:02 PM »
So its running ok now.
A bit strange it's fixed itself but maybe are lucky and have one of them rare self maintaining cars..... you and me wish this were true eh lol  :D
Dave
dadandlad
« Reply #26 on: January 23, 2016, 08:48:17 PM »
Hi Dave
Yes it appears to be running fine and I really do wish I could put my finger on what it was
I think I will replace the spark plug leads with some high quality ones just as a matter of course, they are new ones that are fitted but of unknown make
At least I can move on now
Bambino126
« Reply #27 on: January 25, 2016, 11:51:40 AM »
You said that the copper washer is stopping the jet from seating, well if it works the same way as an idle jet then that will allow too much fuel to flow through at a certain part of the rev range, running too rich. You also said the spark plugs are very sooty, which could be a sign of running rich.
If you're after quality HT leads, I fitted Magnecor ones to mine, I fit them to every car I own because they seem to last forever.
dadandlad
« Reply #28 on: January 25, 2016, 04:04:40 PM »
I assumed that is what was happening with the copper washer and expected it to be a instant fix but it was actually worse
I tried her again yesterday just to be sure and seems to be running really nice
Magnecor are the leads I have been looking at , did you have to fill out the application form or did they already have the spec for them
Bambino126
« Reply #29 on: January 25, 2016, 05:42:51 PM »
I bought my Magnecor leads from Ricambio actually. They are listed as being for the air cooled car, but I asked him specifically if they would fit the Bis so he opened a box and compared the lengths of the leads with a set of Bis leads and they were almost exactly the same.
Of course 1 lead (the king lead) is wasted because the aircooled uses 3 leads and the Bis only 2.
