Author Topic: Parts that make you swear  (Read 11262 times)
dadandlad
Re: Parts that make you swear
« Reply #30 on: July 04, 2016, 06:09:42 PM »
I have changed loads of head gaskets from single cylinder whizz pops to  Detroit 2 stroke twin turbo supercharged V8 s and never had this problem before
I stand by my diagnosis of cheap crappy gasket made of Dairylea CHEESE  ;D
On a more serious note I am going to machine a new set of head washers with a recess to accommodate a O-Ring which should eliminate any chance of water creeping up and around the head studs and into the rocker cover
Xylaquin
« Reply #31 on: July 04, 2016, 06:10:54 PM »
I drive a BIS, and the handbook mentions you get a free service coupon then lists what is included in that service. Notably the first item is "cylinder head bolt torque".
The service should be done "after 600-900 miles".
dadandlad
« Reply #32 on: July 04, 2016, 06:21:15 PM »
Quote
I haven't even done a mile  :o
Bambino126
« Reply #33 on: July 08, 2016, 08:49:12 PM »
I have never had the head off my Bis, but last time I had the rocker cover off to check the valve clearances I decided to check the head bolt tightness.
All bolts needed a quarter turn at least to make the torque wrench click. My car has 60,000 miles on.
cider
« Reply #34 on: July 09, 2016, 02:51:57 PM »
Quote from: dadandlad
[/quote
Yep any of the Black/grey gaskets used on the water Jacket will leak so best to use as a pattern
on 1mm gasket paper
Xylaquin
« Reply #35 on: November 20, 2016, 04:40:00 PM »
the rear panel of a BIS and the absolute pain it is to put it back on. Particularly the nuts on the radiator side.
Why couldn't they mount it some other place, bah.
