Author Topic: Overheating...  (Read 28013 times)
Bar Vitelli
Re: Overheating...
« Reply #45 on: April 18, 2016, 07:57:23 PM »
Well, hours of effort and a small fortune in parts and we've still not cracked it.  :(
To recap, it starts, runs for a bit and sounds fantastic, after about 5 minutes it starts to shake (I think it only has one cylinder working at this point) and then cuts out after a series of shudders.
We've tried lots:
New coil
New condenser
New HT leads
New spark plugs
New fuel sender
New battery
New oil
New petrol
Cleaned the carburettor
Tested the fuel pump
New fuel tubes
Replaced the fuel filter
New rocker shaft
We're running out of ideas and feeling incredibly deflated.
Any ideas or suggestions most welcome.
Every cloud has one...
dadandlad
Re: Overheating...
« Reply #46 on: April 18, 2016, 08:33:02 PM »
Have you checked the valve clearances
When it cuts out have you checked there is any fuel in the carburettor float chamber (remove carb top and have a look)
If it was cutting out dead I would suggest an electrical fault
Slowly dyeing suggests fuel related problem
Offers still there Gary if you want me to call down
Bar Vitelli
Re: Overheating...
« Reply #47 on: April 18, 2016, 08:49:15 PM »
Thanks, Mark, I think both Chris and I will take you up on that.
I'll give you a call later this week to line some time up.
Very much appreciated.
 :thumbup
Re: Overheating...
« Reply #48 on: April 18, 2016, 08:54:34 PM »
I think you need to do a compression test when the engine is hot, after all the items you have replaced and checked the fault must be internal :headscratch:
Bar Vitelli
Re: Overheating...
« Reply #49 on: April 18, 2016, 08:57:05 PM »
Thanks, Pete, I'll add that to the list. Desperate to give Kohli a chance to drive it this year before winter sets back in again.  :thumbup
drcdb15
Re: Overheating...
« Reply #50 on: April 18, 2016, 09:06:46 PM »
This is going to sound both silly and insulting, so please be assured that I don't mean to be, but A) I've just watched your video of it dying, and B) I've just read the whole thread, and I don't see any mention of...
Air starvation.
Now before you scoff, just think: if air was being restricted flowing in through the bodywork grille and ducting into the main fan, then the air supply to the outside of the engine would be too low, hence the overheating, and the air supply to the air filter and hence to the inside of the engine would be too low, hence the cutting out, and the excess of petrol over air leading to the 'too rich' smell.
It's only a theory, but like I say, I don't see any mention of a new air filter, or checking the air ways. Easy test: run the engine as normal (so as to get as much cooling as possible) until it is starting to cut out, then whip off the air filter housing and air filter, or at least disconnect them so that fresh air can get into the inlet without restriction. If my theory is right, the engine should pick up again (but don't let it run too long on unfiltered air and without the full cooling flow).
If my theory is wrong, then the engine will just cut out completely as before.
And now you'll tell me oh yes, we did fit a new filter but forgot to mention it !  ;D
Anyway, really hope it's some blockage in the airway and not a cracked cylinder head  :cry:
Good luck
dadandlad
Re: Overheating...
« Reply #51 on: April 18, 2016, 09:13:13 PM »
No problem Gary,
 I can throw compression tester in the van as well
Bar Vitelli
Re: Overheating...
« Reply #52 on: April 18, 2016, 09:16:36 PM »
Thanks, Mark and thanks everyone for the advice, will add it to the checklist. I think we changed the air filter but it's been so long now I can't remember. Will pop outside and check.
I'm working late next couple of days, Mark and trying to dodge some travelling so will give you a call later this week once I know when I'll be at home. Really appreciate the support.
Bar Vitelli
Re: Overheating...
« Reply #53 on: April 20, 2016, 04:19:42 PM »
Hi Mark, I'm re-motivated and all charged up (wish my car was!)...is any time Friday, Saturday daytime or anytime Sunday this week any good. Please let me know, I'm feeling lucky so got a good feeling that you will crack it in one go!
 ;D
DeVilleChris
    • Club 126 UK
Re: Overheating...
« Reply #54 on: April 20, 2016, 09:37:26 PM »
To me its screaming something internal now, checked valve clearances and what not. the list is endless.
I'm lost on this car!!!!
1979 Fiat 126 DeVille
1979 Fiat 900T Amigo
dadandlad
Re: Overheating...
« Reply #55 on: April 20, 2016, 10:51:48 PM »
Lets have a go Friday evening, any time after 3 is good for me
DeVilleChris
    • Club 126 UK
Re: Overheating...
« Reply #56 on: April 20, 2016, 11:05:18 PM »
I'll be there most of Friday, going to start putting the other engine back together :)
See you then
tmf123
Re: Overheating...
« Reply #57 on: April 20, 2016, 11:43:10 PM »
Watching this post with bated breath! I have the exact same problem with my Fiat 500 D, will go ok for about 9 miles then it overheats. I've changed and re-set everything three times, and I mean everything! Spoke with an old fashioned auto engineer today, he said unleaded petrol runs hotter and to knock the timing back to 4 degrees and it should cool it down. I tried it tonight, but haven't had the time to take it for a proper run. Have you checked the timing on the other (working) cars you have to see what they are set to ?
Please post up your results as soon as and I will do too....
drcdb15
Re: Overheating...
« Reply #58 on: April 21, 2016, 05:01:51 PM »
Can anyone remind me, why exactly is this thread called "Overheating" ? Unless you have a temperature gauge fitted somewhere, how exactly do you *know* that the engines are overheating? The only firm symptom I can recall seeing in the thread (I may have missed it, of course, it's been several months now) is that the engine cuts out after a fairly short time. Are there any other symptoms? Obviously the engine starts when it is cool, and stops after a while when it has warmed up. So it is "heating", but why do you think it is *over* heating?
Until you get to the temperature where the oil is breaking down *can* an air cooled engine overheat?
Bar Vitelli
Re: Overheating...
« Reply #59 on: April 21, 2016, 05:32:53 PM »
Overheating is our current theory but right at the start the engine was definitely overheating because we had a chap with some gadgets measure the temperature in different parts of the engine and the bit on the right hand side was significantly over what Fiat said it should be.  :o
