Author Topic: Brakes (warped drum/s)?  (Read 1807 times)
andyzeetec
  • 126 BIS
« on: June 30, 2015, 01:00:17 PM »
Got the feeling from the pedal of warped drum/s and just wondered how to identify which one it is, or if more than one, or even if it could be something else causing it?
Thanks.
Re: Brakes (warped drum/s)?
« Reply #1 on: June 30, 2015, 02:13:54 PM »
Maybe you could find out by removing the wheel and turning the drum and seeing if it binds at any point. Failing that perhaps a pair of calipers to measure each ones internal diameter
andyzeetec
  • 126 BIS
« Reply #2 on: June 30, 2015, 03:06:27 PM »
Thanks Gadge, I'll give it a go.
