Author Topic: New crankshaft Fiat 500 / 126 with 76 mm stroke  (Read 2255 times)
Piotross
« on: March 30, 2015, 03:33:35 PM »
If anybody interested I have in stock a brand new crankshaft with 76 mm stroke :) for Fiat 500 / 126
By increasing the stroke of the piston increasing the capacity of the engine in a Fiat
Using this crankshaft:
With serial pistons diameter 77,0 mm we have 700 cc
With pistons diameter 80,0 mm (from BIS) we have 760 cc
With pistons diameter 82,0 mm we have 800 cc
With pistons diameter 83,0 mm we have 820 cc
With pistons diameter 86,0 mm we have 875 cc :D
The price is 400£ - it's a good offer, because similar crankshafts with the same stroke 76 mm costs in Italy minimum 800 euro :)
Re: New crankshaft Fiat 500 / 126 with 76 mm stroke
« Reply #1 on: March 30, 2015, 06:57:01 PM »
Hi piotross  :D will you need longer con rods for this crank?
Piotross
« Reply #2 on: March 30, 2015, 07:11:41 PM »
No, con rods are serial. You only need grind the cylinders from below or from above to suitable pistons
« Reply #3 on: March 30, 2015, 07:51:31 PM »
I see is this because the crank will touch the bottom of the cylinder? How much do you think I would need to bring off?
Piotross
« Reply #4 on: March 30, 2015, 07:52:58 PM »
If you use pistons from BIS diameter 80,0 mm you don't have to grind cylinders, because pioston from BIS is 5-6 mm shorter than serial piston 77,0 mm. Just Plug and Play :)
« Last Edit: March 30, 2015, 07:54:36 PM by Piotross »
