Author Topic: Dwell?  (Read 1672 times)
Bambino126
Dwell?
« on: February 21, 2014, 12:01:58 PM »
Where can I get a dwell meter suitable for a 2 cylinder engine?
I want to get my points set more accurately than you can with a feeler gauge, especially when the points have wear.
scotty
    • iamscotty
Re: Dwell?
« Reply #1 on: February 21, 2014, 12:45:31 PM »
As I remember on mine (my neighbour borrowed it and never gave it me back) it had a switch to select 2-4-6 cylinders on it.
It was a Gunstone one as I recall.
I need to have a word with my neighbour. :(
Re: Dwell?
« Reply #2 on: February 21, 2014, 05:00:08 PM »
I think if you multiply the dwell figure you can use a 4 cylinder dwell meter instead.
Bambino126
Re: Dwell?
« Reply #3 on: February 21, 2014, 07:37:25 PM »
My dad has a digital dwell tester that I can borrow, but it says "suitable for 4, 6, and 8 cylinder engines."
So let's say I put it in 4 cylinder mode and connect it to my Bis, do I halve the reading, or double it to get the true reading?
Re: Dwell?
« Reply #4 on: February 21, 2014, 07:56:46 PM »
A dwell meter set on the 4 cylinder setting should have a reading of 39 degrees (which equates to 78 degrees for a 2 cyl)
Bambino126
Re: Dwell?
« Reply #5 on: February 21, 2014, 11:18:12 PM »
Thank you!  :)
