Well so far so good, I have just been on a 20 mile drive and all seems well
Had a mixture of town, a and b road and a dual carriageway blast as well.
I have:
converted to twin coil ignition
Fitted a ballast resistor
replaced the dizzy with a new one and re-set the timing
Fitted new points
Changed the plugs to irridium tipped ones
Changed the plug leads
Cleaned out the fuel lines, electric pump and changed the filter
Cleaned out the carb again
Blasted a can of carb cleaner through the engine while running
Flushed the engine, changed the oil, added some upper cylinder head treatment, run the car then drained the lot out and put in fresh oil.
Put a bottle of nitrox hot shot in the fuel tank.
Seems to be running really well now, got it up to temp and working hard with no loss of power or failures....
Fingers crossed its ok now
