Author Topic: Fuel tank  (Read 2092 times)
Fuel tank
« on: March 20, 2012, 06:43:14 PM »
About how long does it take to change the fuel tank on a BIS, first time, not after lots of practice? Also how high do you need to get it? Clogging fuel filters in less than 200 miles now :(
Marc
126redbomb
Re: Fuel tank
« Reply #1 on: March 20, 2012, 07:06:14 PM »
You're having a rough time of it at the moment aren't you!!
But I hope you get it sorted.
Re: Fuel tank
« Reply #2 on: March 20, 2012, 07:16:05 PM »
It is just getting this tank changed, then a bit of bodywork and making (or getting someone else to) a pair of brackets for my roofrack (Hmmmm, slatty). Still good fun :D (pretty sure I got a front wheel in the air cornering earlier, much to the amusement of the driver of the lowered Astra coming the other :P)
Marc
one of these, if I don't decide it is too big http://www.ebay.co.uk/itm/Vintage-Wooden-Slatted-VW-Beetle-Roof-Rack-/320869509661?pt=UK_Car_Accessories_Touring_Travel&hash=item4ab5502a1d#ht_500wt_1287
« Last Edit: March 20, 2012, 07:23:25 PM by Hazey-n-Marc »
Re: Fuel tank
« Reply #3 on: March 20, 2012, 09:25:23 PM »
Marc I'm about all next week if you want to come over and I can help to sort it- give a me a shout if you want to.
Re: Fuel tank
« Reply #4 on: March 21, 2012, 08:30:55 AM »
Sonds gooud chairs :D. Is any day better than another?
Marc
Re: Fuel tank
« Reply #5 on: March 21, 2012, 09:24:35 AM »
and day apart from friday is great but wednesday would be the preferred day.
give me a bell if need be.
Re: Fuel tank
« Reply #6 on: March 21, 2012, 06:15:29 PM »
Wednesdays are nigh on impossible for me, would the tuesday or thursday be ok?
Re: Fuel tank
« Reply #7 on: March 21, 2012, 10:30:27 PM »
the fuel tank is easy enough to remove just make sure that you empty it as much as you can before doing so and make sure that the car is raised enough for you to withdraw the tank from underneath the car. make sure you disconnect the filler and breather pipes inside the car (behind the rear passenger doorcard/panel) before you go underneath and make note of the sender wiring connections before pulling them off. the nuts that hold the tank on should come off easy enough i have never had any trouble, make sure you clean the threads up and give them a good lube up before reassembly also while the tanks off get the underseal out and do the now visible underside.
Re: Fuel tank
« Reply #8 on: March 21, 2012, 10:41:45 PM »
Sounds like a good excuse for a random drive :D, cheers for the info.
Marc
