Author Topic: Bis rear bump stops.  (Read 5010 times)
Re: Bis rear bump stops.
« Reply #15 on: October 30, 2011, 04:31:44 PM »
Here is my BIS bump stop and both BIS's I have owned they have been the same, they measure 8.5 cm long.
« Reply #16 on: October 30, 2011, 05:00:11 PM »
That is interesting. The pictures of the old ones from my Bis appear to be slotted into place and not screwed in. Does your rear bump stop screw into place like the aircooled version that I just bought?
« Last Edit: October 30, 2011, 05:02:40 PM by Amateb8 »
« Reply #17 on: November 05, 2011, 05:56:37 PM »
Placed my Bis on a ramp today to checked out whether an aircooled screw type rear bump stop would fit. It does not! You are probably saying, I told you so, but I was hoping with some modification to the bump stop it would be possible to make it fit. It has to be a bump stop with a plastic nipple that fits into the chassis. I'll check out other rear bump stops from other make and models.
« Last Edit: November 12, 2011, 01:26:35 PM by Amateb8 »
« Reply #18 on: November 08, 2011, 08:58:55 PM »
Franco from Ricambio can get the (correct?) rear bump stop for a 126 Bis for a whopping £25+VAT each. I wonder whether any one has used another rear bump stop from another make.
« Last Edit: November 12, 2011, 01:27:22 PM by Amateb8 »
Re: Bis rear bump stops still available from Fiat.
« Reply #19 on: November 12, 2011, 12:51:17 PM »
Good news. Just took a chance and popped into my local Fiat dealer, to find that they still stock the 126 Bis rear bump stops! Hooray!! A bit pricey at £54 for the pair. I just ordered a pair. Part no is F0007688142.
Ciaoflyer, looked at the bump stop picture magnified from the Fiat computer, yup, your bump stop is indeed original.
« Last Edit: November 13, 2011, 12:05:44 PM by Amateb8 »
126blackbird
« Reply #20 on: November 12, 2011, 05:12:32 PM »
Can you bring those bump stops that you bought from 126skfan to the 8ball dinner, I may be able to use them.
Draigflag
  • Got a New Abarth 500 too!
« Reply #21 on: November 12, 2011, 08:08:51 PM »
Can't belive they still stock BIS parts! That's mad!
« Reply #22 on: November 12, 2011, 09:13:45 PM »
The chap behind the counter could not believe it himself but he was quite happy that they did. I also bought the original string that attaches to the parcel shelf and to the hatch, so that the parcel goes up when you lift the hatch. They could also still get the plastic bumpers as well.
« Reply #23 on: November 12, 2011, 11:17:57 PM »
Good news. Just took a chance and popped into my local Fiat dealer and they still stock the 126 Bis rear bump stops! Hooray!! A bit pricey at £54 for the pair. I just ordered a pair. Part no is F0007688142.
GREAT!  Similar price to ricambio though!  Who are their suppliers?
« Reply #24 on: November 13, 2011, 12:42:41 PM »
Ricambio quoted £25 each plus VAT for a similar bump stop. Not sure if it is from Fiat. I suppose, bottomline, a rear bump stop from other makes is fine as long as it fits.
Da Londo
    • Fiat 126 blog
« Reply #25 on: November 16, 2011, 03:52:58 PM »
It is often recommended to check for parts at Fiat itself or local car parts dealers, they can be cheaper than online stores.
« Reply #26 on: December 03, 2011, 03:17:06 PM »
Here is one of two the bump stops a bought from my local Fiat dealer. The pictures I previously posted were the original ones. There are probably many variants of the rear bump stops depending on the supplier.
The label states, "Made in Italy" or in reality, perhaps it should say, "Made in Poland".
« Last Edit: December 03, 2011, 04:01:55 PM by Amateb8 »
