Author Topic: Handbrake cable.  (Read 1302 times)
Kipster
Handbrake cable.
« on: June 26, 2011, 06:19:43 AM »
Right i'm not paul daniels, can someone explain how to remove a handbrake cable?
I have released the cable from the rearlink arms, released the retaining u brackets, removed the rear seat, removed the bit of tin, carpet pulled back, hand brake assembly pulled out...I can see the assembly with the wheel which i fully understand the bit about removing the pin to release the cable.
But, how do i remove the cable from the car body, it is almost as if the cable has been made after passing the wire through the bulk head????  I just cant fathom it. Help.
Re: Handbrake cable.
« Reply #1 on: June 26, 2011, 08:47:29 AM »
You have to remove the grommets from the adjacent larger holes, slide the inner cable across the slit then the cable can be threaded through the larger hole  :)
Kipster
« Reply #2 on: June 26, 2011, 05:10:11 PM »
Thanks for that i will look again next weekend.
Still confused as i saw no grommets, knowing this car someone has body filled them.
Kipster
« Reply #3 on: November 10, 2011, 07:10:23 PM »
MOT is due and i have beeen lazy.
Ok this handbrake cable, i have a new one and attemted to fit it, but failed.
When i remove the carpet/seat etc on my 73 126 there is no groove or grommet to remove the cable. I just have two holes in the bulkhead where the cable and outer pass through.
The cables cannot be slid/guided or sent anywhere else? I am so confused.
When i look from inside the car i have two holes with cable/surrounds inserted,( no grooves large holes or grommits are visible). It seems like the bloody car was built around the worn cable.
Any ideas please, get this sorted and i will be at the 8ball.....OK. :)
