Author Topic: Head Bolts With Hole Through It  (Read 1916 times)
triantis
« on: December 16, 2010, 02:14:00 AM »
Another question for everyone. Ive noticed on the head (i thinki below where the exhaust mounts?) there is a bolt with a hole through it. After driving I get some oil blowing out the hole. The engine runs fine and drives well. Is this normal? what is the purpose of the hole? and what would happen if say i decided to block the hole with a bolt?
triantis
Re: Head Bolts With Hole Through It
« Reply #1 on: December 16, 2010, 05:46:50 AM »
It makes sense that the hollow bolt could be something to do with the head gasket? but the car still runs fine... I will look into confirming the oil is coming from that hole.
« Reply #2 on: December 16, 2010, 01:10:57 PM »
that is a safety device that is fitted in case the head gasket fails, it then means that the exhaust gases would then exit via the hole and suppossibly not into the car via the heating tunnel. if you have a little oil seepage it may be that the piston rings are letting a little through due to wear or that it is entering via the valve seals. by the way if the head gasket has gone it will be bloody hot gas escaping so be carefull as it will burn you!
« Last Edit: December 16, 2010, 01:12:31 PM by bis13 »
« Reply #3 on: December 16, 2010, 02:30:15 PM »
Ditto what bis-man says as they are the only ways that oil can come out of that bolt. You would also use a fair bit of oil and have a smokey exhaust. You say the engine is running OK which is possible as some very worn engines go through a "sweet spot" just before they let go. However before you panic I would check for oil leaks around the rocker box & oil filler cap. After my recent top end rebuild , massive overheat then re-rebuild I had oil appearing in many places & I was convinced something had blown. Turned out I had not nipped down the rocker cover enough or the rear nut had come loose and the oil leak was not really visable there as the oil woil flow down over the very hot top end then get on the exhaust & base of the engine etc  :D
