Author Topic: Pulling to the near side!  (Read 2394 times)
« on: November 19, 2010, 07:22:41 PM »
Replaced the front suspension recently and also front break pipes,  all fine suspension wise but when I press the breaks it pull slightly to the right!  Could I have contaminated the shoes with break fluid?
Any thoughts?
Re: Pulling to the near side!
« Reply #1 on: November 19, 2010, 07:55:36 PM »
Most likely.
There's nothing else it can be if it doesnt pull until you push the brakes.
smallcox
« Reply #2 on: November 19, 2010, 08:59:42 PM »
PULLING TO THE NEAR SIDE
Is that classed as curb crawling :P
If you jack the car up does both lh/rh turn freely, ie binding on one side. I had the same problem some time back but this was related to the master cyclinder but again grease contamination on brake linings will do the same thing. Can you swoop the brake shoes from lh side to rh side a see if the car then pulls to the OFFSIDE if not master cyclinder may be at fault :-
« Reply #3 on: November 19, 2010, 10:15:12 PM »
I had a similar problem when I had a 600D. It ended up to be a leak in the rear wheel cylinder.
« Reply #4 on: November 19, 2010, 11:33:33 PM »
I can't quite make out how you think you have contaminated the BRAKE shoes by changing the brake pipes  ???
Brake fluid can only get into the drum past worn cylinder seals . So in the first instance I would make sure that the BRAKES have been bled properly  [-/
If you have leaky cylinders then they need replacing or new seals and they are as cheap as chips if you plan ahead or get lucky on eBay. I am amazed at the number of guys out there that have a "crisis management" approach to running a classic car which is why some of the suppliers that put on big mark up on parts keep going.
If you do get some brake fluid on your brake shoes I used to throw them away as oil & brake friction do not mix. Then I realised that brake fluid is water soluable so an immersion in water , with a dash of washing up liquid to act as a wetting agent , will get them back on track when dried out  ;D
« Reply #5 on: November 20, 2010, 08:26:30 AM »
Forgot to tighten unions when I was bleeding so the fluid poured out :oops:  It must of got on the shoes!
smallcox
« Reply #6 on: November 20, 2010, 11:23:53 AM »
I like your your thinking rusty, never tried this on brakes due to shoes being as cheap as chips but,............ must confessed a good friend off mine explained to me about getting oil off the driveway, you know the black dripping oil thats been there years and will not wash off. The solution neat washing powder (persil) or cheap brand. Just sprinkle the powder on and leave it, when it rains next the oil disapears. I have tryed this on contaminated clutch plates and it works just pop the clutch in a plastic bag with washing powder for a few days and  [-/
« Reply #7 on: November 20, 2010, 12:46:32 PM »
We always washed brake parts in a bucket of hot water with trisodium phosphate. It cleans off all the oil, grease and brake dust. Afterwards just needs to be dried with compressed air. Of course it's best to wash with this if you pull the whole thing apart and upon reassembling you put copper grease to the places/surfaces where the shoes move on (and other moving parts).
Brake cleaner's good but not as strong as this stuff...
